kentb Posted June 26, 2008 Report Posted June 26, 2008 does this look right? they will be fused. just making sure. thanks in advance New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
Derrick824 Posted June 26, 2008 Report Posted June 26, 2008 If it was me, instead of pulling all three power & grounds for the amps off the last batt, I would split them up and pull one power & ground off each battery.
kentb Posted June 26, 2008 Author Report Posted June 26, 2008 i thought of that too, but wasn't sure. thanks alot. New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
MECHMAN Posted June 26, 2008 Report Posted June 26, 2008 If it was me, instead of pulling all three power & grounds for the amps off the last batt, I would split them up and pull one power & ground off each battery. +1 aside from that it looks good. 1-888-MECHMAN www.Mechman.com [email protected]
Kicker Guy Posted June 26, 2008 Report Posted June 26, 2008 Also when grounding that way make sure its to the Frame... better current flow then you would get from the body. Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
