I just got a 98 chevy malibu and Im planning on putting 4 12's in it. My question is how big of an amp can I use without frying the stock alternator? I was thinking of gettin an 1800 watt 4 channel amp.
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
Do I really need a 150 amp alt and 2 batteries for one 1800 watt amp?
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
yes
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
1800 watt 4 channel? what brand/model # is the amp?
DC.jpgDC POWER
Ya x2
I didn't even catch the 4 channel part.
Class A/B
Thats going to pull alot of current if it was to be ran with subs only.
Have you thought about a Mono amp instead?
and your lucky that malibu alt is right on top you could change alts in under 20minutes mine is underneath the motor where you can't reach from the top and can't reach from the bottom.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Am I gonna be able to run 4 subs off of a mono amp?
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
you can run as many subs as you want off of 1 amp as long as you dont go below the safe ohm load on the amp.
