but but it was my idea... haha jp man but i dont think the box will hold a current unless the wires are touching the box itself and not the sub as long as you dont let any bare wires touch the box i think youd be good.
That's what I wanted to hear. The thought just popped into my head this morning while I was thinking about how to build the box. I think I may just model it after my current box and see if it sounds good in my truck.
that would be perfect unless your current box is huge lol then if it does fail youre wasting alot of steel but you can compare the two and tell us what you think
Thats a waste of marble mannn... It would be my end table by now
Think that the box being made of metal would hold current and shock someone from touching it or maybe short out somehow???? I just though about that possibility.  :meh:
ya how would you connect the speaker to the amp?  you would almost have to run it thru the port, a terminal cup would just explode and the box is metal so you cant put bolts thru it
new setup in the works
That's fine, I could run it through the port then. Why couldn't I put bolts through it???
It's not that it's huge, just kinda odd shaped. It gets smaller in depth behind the center seat.
grommet wire wire through it. the terminal cup wouldnt explode though. you can also just drill a hole and instead of a grommet, silicone it.
  • Who's Online   0 Members, 0 Anonymous, 1065 Guests (See full list)
