A. You have 4 15's you still need atleast a depth of 31".
B. Are you building this box inside of the trunk?
29" is the depth... :ph34r:
It is going in a 92 Dynasty B)
I already have it gutted right now.
I'll try and get a pic of the area I'm working with later tonight.
Amps will be mounted up in the trunk, behind the wall.
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
No Its going exactly where the rear seats were at.
Yep, amps gonna get mounted in the trunk with the batts and such.
Mazdaspl: I love that box!!!! :wub:
If I really need a depth of 31", then I can make it 31 inches... :ph34r:
I was going with 29 cause I have my seat tilted back, but I can make 31, 32 no problem.
Quick question: the box that Mazdaspl drew up, can a box that type be tuned to around 32Hz?
Derp.
I designed it a for 32hz. i made the port 32inches high by 5.5wide and only 9inches deep. by making the port that high it made the box 32.75 high. i did not know if you could get .75 more inches where you going to install it.
good luck bro
Jay
good luck bro
Jay
Yeah, I can squeeze an extra .75" in their.
So based off of my dimensions (Plus the extra .75 for height) and your dimensions for the port/tuning I just build it how its seen in the design? With the same kind of 2x4 bracing?
If so, what would the front of the box on each side of the port be cut at? (inches I mean)
Actually I could probably just subtract from the port width huh? :P
Derp.
