1997 Toyota Celica 15" Havoc Build
not a very eventful outing started by sanding box
Posted Image
and primering
Posted Image
carpet started going in
Posted Image
not happy at all with spray on bedliner, it will be changing soon, oh and ports are contact cemented together...but i still duct taped them lol
Posted Image
Posted Image
Posted Image
Posted Image
more pics of shitty finish or rubberized bedliner
Posted Image
Posted Image
Posted Image
its not staying that way...
I started wiring doors before i left last night
Posted Image
Posted Image
Dangling crossover
Posted Image
still a decent amount of stuff to do, front stage still needs installed have to mount 3" mids and tweets still as well as wait on amps in the mail.
Couldnt find covering for board for bottom of trunk yesterday, so that sucked as well. overall the day kinda sucked.
nice progress...the box looks good
question: did you run fresh wire from inside of the car, through the duct into the door to the speakers? or did you just 'tap' into the factory wiring?
if you ran your own wiring, what is your strategy for getting the wire through the wretched duct between the door and car? lol
its all new wireing non of the stock wiring is used and we used a coat hanger with wire taped to it and dish soap
What are those ports made out of if its the right thing you could use pvc cement like people use in plumbing
its like abs plastic id guess its kinda thin. the contact cement and duct tape is perfectly fine as its never seen.
Well one door was done dry and that was a pain the arse got the idea for the second door but thinking about it vaseline would probably work better because it wont dry out as easy.
