trappin859 Posted July 7, 2008 Report Share Posted July 7, 2008 (edited) the link to the site is a little laggy is there anything else ... and another question ... what should i do to get the most of these sub ?? Is you box ported, or sealed? What is the cubic feet of your box? If you're using a prefab ported, get rid of it because chances are it is tuned way too high. Powermaster, Ohio Generator, and Iraggi are other alternator brands you could look into. Edited July 7, 2008 by trappin859 Quote Current '09 mazda3 4dr clarion hu 2x 10 fi X subs(looking to upgrade) amp(looking) Alpine type-r comps in front type-r coaxials in rear Link to comment Share on other sites More sharing options...
AI James Posted July 7, 2008 Report Share Posted July 7, 2008 if all his wirings correct he shouldnt need an alternator for a kicker 750 im betting theres a bad ground somewhere Quote Link to comment Share on other sites More sharing options...
imnasty08 Posted July 7, 2008 Author Report Share Posted July 7, 2008 if all his wirings correct he shouldnt need an alternator for a kicker 750 im betting theres a bad ground somewhere if the ground wiring was wrong what are the chances of it being done wrong twice... cause i just upgraded to the 4 gauge a week ago... by a different guy ... what u think ... are these alternators good for hondas they mostly say like gm and chevies ... Quote Link to comment Share on other sites More sharing options...
ISO Posted July 7, 2008 Report Share Posted July 7, 2008 (edited) Well you don't need to get a new alt for the 750.1. You do need to work with your wiring to get a better current flow. As a last resort you might need to change your constant battery lead and/or ignition wire turn on but thats very rare. Edited July 7, 2008 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
imnasty08 Posted July 7, 2008 Author Report Share Posted July 7, 2008 Well you don't need to get a new alt for the 750.1.You do need to work with your wiring to get a better current flow. As a last resort you might need to change your constant battery lead and/or ignition wire turn on but thats very rare. alright so right now im probably looking at a good dry cell battery does everyone agree? Quote Link to comment Share on other sites More sharing options...
etaks_crew Posted July 7, 2008 Report Share Posted July 7, 2008 (edited) Is the Remote wire thats hooked up to your amp the same remote that will to turn you CD player on? Edited July 7, 2008 by etaks_crew Quote Link to comment Share on other sites More sharing options...
ISO Posted July 7, 2008 Report Share Posted July 7, 2008 alright so right now im probably looking at a good dry cell battery does everyone agree? I agree, I think you should beable to get away with putting a quality deep cycle in place of your original. I personally like the Stinger Power 2 Batteries. I use the SP1000. Its fairly small and very powerful but it is expensive. ($250ish) There are other companies to look at too Kinetik, Power Master, are the other 2 companies right off the top of my head. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
ISO Posted July 7, 2008 Report Share Posted July 7, 2008 (edited) You want to make sure all of your grounds are done properly. Did you make sure to remove all paint from the spots that you have your grounds attached too? Edited July 7, 2008 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
jmsonoma03 Posted July 7, 2008 Report Share Posted July 7, 2008 what do you mean by the deck restarts does it completely turn off then back on when it does it do you lose the clock and preset memory or does it just skip .everyone always jumps to its a voltage problem but you might have a bad ground or const power to the deck. Quote Link to comment Share on other sites More sharing options...
Torres Posted July 7, 2008 Report Share Posted July 7, 2008 if the ground wiring was wrong what are the chances of it being done wrong twice... if the first ground was bad...and you're using the same ground. then chances are high. make sure it's all on bare metal. or relocate it to a more solid location Quote Link to comment Share on other sites More sharing options...
