EricR Posted July 19, 2009 Report Posted July 19, 2009 hes building a wall behind the seats not in the trunk. poast some pics dude. my 18's should be here by next week but i still have to get all my electrical done damn thats almost 20 cubes :wow: i could have squeezed in a few more also but i like to get my lean on while drifting. i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
J00bles Posted July 19, 2009 Report Posted July 19, 2009 but i like to get my lean on while drifting. in your impala sitting on 20's? ...but yea.. glad to see that the DC bug bit you hardest. just be sure to throw some power at them. im willing to bet that they are louder than your 8's when its all said and done http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.gif 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
raytard Posted July 20, 2009 Author Report Posted July 20, 2009 they damn well better be louder than the 8's and for those of you that missed it, 3 jbl gto14001's, one for each sub (so 1500rms...i know they take more, but goddamn, its 3 18's and nearing 5kw in a sedan) and so on with the nights update.... morning started with a lot of double checking my measurements and doing some cutting then the car went under the knife before it got too hot out, no more rear deck or brace or seat mount or anything...all the bumps got banged in flat to get me every inch possible, just like the tirewell with the batts then i started test fitting for the box, and went on to build it (after wiring all the batts in, soldering all the lugs, fusing the 0g runs from the front and running them to where the busbars will be, putting some deadener in select spots, etc...i didnt take pictures of everything because its boring and you've all seen it before and i want this shit done and banging like asap) batts are under floor, and every side except for the double (soon to be triple) baffled rear touches metal and couldnt go 1/32 of an inch farther there will not be a wall, more of a half wall, and port up, its the only way i could get the subs and port to fit in the space i had (so dont let this pic fool you, it was a test fit of what kind of room i had to play with) and by the end of the night i had this, all corners of the port are 45'd, rear is double baffled (the good way where the first one fits in and the second one fits over), theres supports all under so its sits flat and doesnt shift, and the port is like 38.5x6x40 long keep in mind this is about 11 hours of work between measuring, cutting, grinding, bashing with a hammer, soldering, screwing, etc. i'm beat. i'll update tomorrow night with whatever I finish, i'm hoping to have the front box installed, all 3 baffles, and the fiberglass hump atleast fleeced and resined, and maybe my highs amp back in so i'm not jamming out to windnoise Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
raytard Posted July 20, 2009 Author Report Posted July 20, 2009 well even though noone is showing any love, heres the update. started the day with new grounds and finishing some wiring...50 feet of stinger expert gone, in additing to 20 feet each of monster and rockford. you can see in the pics the clearance i have between the box and strut towers put a floor and sides on the box and such, some 45's, some reinforcements, you know, making that shit bulletproof started on the baffles...all 3 of them with 2x4 reinforcements behind...2.25in of mdf and 2x4 bracing should keep it solid so thats all for now. on the baffle, the top sub sticks above the box, the flat parts will be even with the rest of the box, and a fiberglass bubble of sorts will connect the top ring to the roof of the rest of the box, if that makes any sense Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
EricR Posted July 21, 2009 Report Posted July 21, 2009 damn you cut all of your rear deck out got more balls than i do. so you said your dad is helping you with this shit? thats awesome man. i wish i still lived close to my dad. when i was 17 he helped me build a bandpass using birch and plexi. i'll never forget that. how do you like cutting those rings out with that piece of shit jigsaw lol. i have the same one and i wanted to throw that thing out in the street. i probably just need a new blade its still the same one from 4 boxes ago. anyways seeing all this is gettin me amped up to finish my shit. im ordering 120 feet of 1/0 friday and my custom made 18's with aluminum coils should be here middle of next week keep the pics comin i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
basshead4life Posted July 21, 2009 Report Posted July 21, 2009 how do you like cutting those rings out with that piece of shit jigsaw lol. i have the same one and i wanted to throw that thing out in the street. i probably just need a new blade its still the same one from 4 boxes ago. wow ive had my jigsaw for 7 years and only used like 4 blades. proply why it cuts like shit Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
87accord Posted July 21, 2009 Report Posted July 21, 2009 it looks dam good so far keep up the work and get us some vids new system in the works (3) DC lvl 4xls 15's (one of three are here) (2) DD z1 (done) old kenwood four ch 4 runs of 2/0 (done) ? 200 amp alt may two ??
raytard Posted July 21, 2009 Author Report Posted July 21, 2009 the jigsaw wasnt so bad, but those stupid "comfort gel grips" give me a mean blister every time i use it hard, like i am now. it just rubs this random part of my palm there isnt a callous on. and i'm on the 3rd blade this year, and it doesnt get used much. Sharp blade=faster cleaner cuts, so worth the dollar or whatever the thing costs. But my dad has been a huge help, a lot of this stuff was a 2 person job and having someone around that knows what they're doing is invaluable. But there will hopefully be a pic or two tomorrow, I want to finish the baffles and such. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
BASS14 Posted July 21, 2009 Report Posted July 21, 2009 loooks great! cant wait to see this beast done Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessionsSubs-4 8" sundown audio E8v3 Sub Amp-Hifonics Brutus Elite 1200.1box-2.8cubes after all dis tuned to 32hz 4" aeroMids and highs-2 sets of Memphis PR 6.5 components Mids amp-Hifonics Brutus Elite 800.4 Deck-Factory IntegrationWiring-Memphis40sqft of damplifier Pro http://www.youtube.c...14?feature=mheeSMD SUPER BUYER/SELLER
enemyofsilence Posted July 21, 2009 Report Posted July 21, 2009 looking good man. keep it up. Team Bass-Hz
