Mudrunner Fiberglass Body........needs A Little Repair Work
this thing is gonna be pretty solid. good thing is you dont have to sand all that in there :)
exactly.............a little sanding here and there...but nothing major..
My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
Posted Image
steel plates for the front mounts....fully buried in the glass
Posted Image
my card.....buried in the glass
Posted Image
Posted Image
at the back.......it was cut out for the tires.....but the cuts were way off from side to side....so im going to clean them up
heres a pic from the beginning of the thread....look at the chopped up cutouts for the wheels
Posted Image
So I begin with drawing out some cut lines....measuring everything off....Center
Posted Image
Posted Image
Posted Image
all the areas that were cracked.....well they are NOT breaking again...with all the repair work done to the inside...But Im going to grind them down and do a couple layers on the outside as well....Because i loke to take those extra precautions
Posted Image
Not enjoying......grinding glass @ 90 degrees
Posted Image
all trimmed up and symmetrical from side to side.....Just the way i like it....but you can see in the upper right corner.....i need to add some glass
Posted Image
One of the many areas where the body was busted.....I built it up on the inside,,,,now grind down the outside...so i can glass it up as well
Posted Image
a couple more spots on the other side
Posted Image
as you can see........this corner was real bad
Posted Image
here is that missing chunk......so i need to build it up again...
Posted Image
more areas on the other side.....and another crack i still have to grind down and glass
Posted Image
put in a foiled cardboard backer......
Posted Image
more layup
Posted Image
I picked up some....3/4"wide 1/8" thick steel and made a L brace on each side....
Posted Image
Great work.... Your threads are the reason I did my last build (mold of my midgate). Until I tried it I had no clue how much work was really involved in glassing. Again great work
Rebuild coming soon
well Chris....a box of 24 usually lasts me over a year....if i squeeze the resin out of the brush after im done ....and submerges it in Acetone....I can use the same brush about 40 times...
Anal, smart, just wow...I do the squeeze & acetone soak too, but not thoroughly enough to get 40 damn uses...maybe 5-8 at best...you think maybe it's partly cuz I use the junky-bondo brand stuff too? or just being too lazy to get more of it squeezed out b4 I soak?
It really is alot of work Patrick....alot of work....to do it "what i consider" the right way....the previous work on this thing is some really shitty work....and i feel if i dont get all that garbage out of there ...its just gonna break again...there is an unbelievable amount of ....just straight resin pools..on the inside of this ol bitch...
So you're saying it basically looked I had built it originally? I don't think there are machines out there with your patience/ability/determination/skill to do it as right you do Tim.
I would really doubt with as much prep work and clean layup as Tim does, he would have much to do on the exterior either.
Sorry I'm late to the party, but it's lookin great Tim. Nice and solid as you always bring it, and much nicer on the line cleanup-hopefully he notices/understands/appreciates what he's getting out of you.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
thanks alot man
Thanks alot Chris............as you know ,your comments are always ,,,greatly appreciated,,
got that little corner patched in
Posted Image
Posted Image
Posted Image
and some glass added to the Outside of the body...where the cracks were....
Posted Image
Posted Image
Posted Image
  • Who's Online   0 Members, 0 Anonymous, 1935 Guests (See full list)
