RE MT Specs
Mr. 973808
I had my mt 18 measured on leap software and it came out to an fs of 41.5 Hz, a Vas of 2.193 and a qts of.41, but thats all i got. Im pretty sure its correct i didnt do it a teacher at installer institute did it.
Also, not to tread jack but ray, I asked about a box for my mt's and you asked for my adress and i dunno if you got around to it or not but i never got it. if not, thats cool i understand your busy tryin to do your own thing, i was j/w
Guest MegaloManiac
Hey Steve, what are the specs for the RE MT line. Cause whenever I go to their site to get some they don't give the specs. The specs that I'm lookin for in particular are the MT 15's and MT 18's. :help:
Mt's were designed for pure SPL, it can be used for daily drving. There is no set rating for them. But i can tell you they can take a lot of power. I heard of ppl throwing 10k to them, not daily...the burp was at high note....
but for dailyin thumpin u can give them around 1k-5k daily. as far as schematics on them....
MT Series
10”
Mounting Depth - 7.25”
Mounting Hole Diameter - 9.25”
Overall Diameter - 11”
Bolt Hole Circle - 10.125”
Motor Width - 9”
Motor Depth - 4.5”
Basket Depth - 2.75”
Displacement - .18 cu. ft.
Weight - 57 lbs.
12”
Mounting Depth - 8”
Mounting Hole Diameter - 11”
Overall Diameter - 12.5”
Bolt Hole Circle - 11.75”
Motor Width - 9”
Motor Depth - 4.5”
Basket Depth - 3.25”
Displacement - .19 cu. ft.
Weight - 58 lbs.
15”
Mounting Depth - 9”
Mounting Hole Diameter - 14”
Overall Diameter - 15.5”
Bolt Hole Circle - 14.75”
Motor Width - 9”
Motor Depth - 4.5”
Basket Depth - 4.5”
Displacement - .21 cu. ft.
Weight - 61 lbs.
18”
Mounting Depth - 10.75”
Mounting Hole Diameter - 16.75”
Overall Diameter - 18.5”
Bolt Hole Circle - 17.5”
Motor Width - 9”
Motor Depth - 4.5”
Basket Depth - 6.25”
Displacement - .25 cu. ft.
Weight - 62 lbs.
They dont show specs ALSO because, they are custom built subs, you order them based on how many spiders you want, and coil configs...  Fs/Qts/Qes all change with more/less Winding width area on coils, LE changes with coil resistance, layers.... I would say to many versions to be posting ALL of them on a site
I do know, they have insane BL that rivals just about all other woofers, and BL is pretty damn important in SPL
major payne i have your box in front of me, i have been trying to setup a way so you can open it in an email.. but i dont think thats gonna work.
so, external dimensions are 35" tall, 53" wide, 16" deep double baffle the front , subs and port back
port is 13.75" x 13" and 35.75 long
tuned to 32hz 9.6cuft after
i will snail mail it to you
Aw shit ray dude my bad its goin in an extended cab s-10 i dont think subs up  port back will work lol I hate to burst your bubble i should have mentioned it earlier
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
