AI James Posted July 10, 2008 Author Report Posted July 10, 2008 you dont think jb weld would do the trick?
william8550 Posted July 10, 2008 Report Posted July 10, 2008 a closer look i would have to say there's no fucking way its gonna hold but no one now's for sure till u try it...
AI James Posted July 10, 2008 Author Report Posted July 10, 2008 meh worse case scenario it breaks and i pay, thought id get some thoughts
ISO Posted July 10, 2008 Report Posted July 10, 2008 Well the biggest issue with the JB weld liquid is squeezeing it all out when you compress the pieces back to gether. They do make a JB weld stick that you break off a piece and mix it in your hand and it might be worth a shot. I'll try and get you a link. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
ISO Posted July 10, 2008 Report Posted July 10, 2008 Hers a list of all the products. http://www.jbweld.net/products/index.php Hers what I'm thinking about. http://www.jbweld.net/products/jbstik.php I have only used these 2 products and they might offer something better. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
ISO Posted July 10, 2008 Report Posted July 10, 2008 The stick won't squeeze out as easy. just don't put abunch of pressure when adhereing the 2 sufaces. Give it a good 24 hours before touching it. Good Luck Man and I want to know how it turns out. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
AI James Posted July 10, 2008 Author Report Posted July 10, 2008 in about an hour im going to get some stuff so i guess i'll take pics of the process so all can watch the stupidity of saving a sub because your to cheap to get a recone
hotshot27 Posted July 10, 2008 Report Posted July 10, 2008 damn, i would invert it with sub firing down, thats a big break. hope it works out for you though Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
ISO Posted July 10, 2008 Report Posted July 10, 2008 Man If it was me I would send that pic to JB weld tech support and it might up your chances of success. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
AI James Posted July 10, 2008 Author Report Posted July 10, 2008 damn, i would invert it with sub firing down, thats a big break. hope it works out for you thoughit was free, i am just tryign to get out of paying lolas stated though i'll see what harbor frieght has and probably take pics as i do it this evening
