I got a 12volt fan from walmart for under 10 bucks, plugs into ciagarette lighter, but i direct wired it by my amp, and it keeps things pretty cool
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
I'm a fan of these.
http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1
The only draw back to them, they are only good up to around 2.5 inches of air flow.
So they need to be mounted pretty darn close to the amp to be worth anything.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I'm no expert but you need to get over 13 volts.
The more voltage = less amperage = less heat build up.
The voltage is around 13.3-12.7 when im playin music, it only drops down lower than that when i let someone listen to it & really turn it up. Still waiting for the MLA module but he said it will be a few more weeks
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Man I don't have anymore advice except get your voltage up higher and try and mount some fans in there.
See if you can come up with a better ground circuit.
I'm tapped out.
I'm tapped out.
Thanks
MLA module 15+volts
Team Bass Hz
Only if you have a regulated power supply in your amp.
If it's unregulated, current stays the same, you just increase the power output by increasing the voltage input :)
What impedance are you running the amp at?
10.x volts fo' life!
get one or 2 of these, http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1 my friend put some on the ends of the m4kd to keep it cool, he was only runnin 2 mtx 9500 15 dual 4's off it
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
I was thinking I should point out that some companies use a unregulated/regulated power supply in their amps to make sure they make the minimum rated power under most circumstances.
Examples would be Rockford Fosgate and its INDIGO circuit and Zapco are 2 rite off the top of my head.
Another thing to think about is 4,000 watts in reality is a very large amount of power and if I was to guess Memphis most likely uses a similar system to help garuntee that that amp attempts to make rated power.
Edited by ISO
1 ohm
MLA module 15+volts
Team Bass Hz
  • Who's Online   1 Member, 1 Anonymous (See full list)
