Is My Electrical Setup Ok?
Can some one let me know if this electrical setup will support my install? Should I step anything up?
140 or 160 ho alt..(don't have yet)....Yellow top under the hood. One run of pos. and neg. 1/0 gauge Knukonceptz KLM wire to trunk. A Powermaster D925 in the trunk.
The setup this will be running is two Elemental Designs ED Nine.1(1200 watts rms at 1ohm each), and a two channel amp thats approx. 100x2(undecided on this amp)
run a bigger battery in the trunk, either a D3100, 9a31, or hc2400.
everything else is fine.
edit: yes it is 1/0. do the Big 3 too. then you shouldnt even have voltage drops, if so, very little.
So one run of each in 1/0 gauge should be ok?
Yes, as long as it is high quality wire. Make sure that you ground to either the same side frame rail, or the same side sub-frame if it is a unibody vehicle. What kind of car is it?
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
