1LoudCelica Posted August 8, 2008 Report Posted August 8, 2008 could anyone give me a quick list of the loads I could get from 24 dual 4 woofers? Need to know before I purchase this amp i'm looking at. I know I know, do it yourself, but this multiple wiring confuses me after a few woofers lol. any help is appreciated.
Stephen Posted August 8, 2008 Report Posted August 8, 2008 i came up with 1.34 but i dont feel like doing anymore you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
1LoudCelica Posted August 8, 2008 Author Report Posted August 8, 2008 i came up with 1.34 but i dont feel like doing anymore yea i had the 1.3 one done and then I just spazzed out after that.... figured maybe peeps here would be like omg i get to do ohm loads! ! lol.. stuff is a headache
Torres Posted August 8, 2008 Report Posted August 8, 2008 yeah it's always gonna be an odd ohm load. 1.3 is the lowest, then there are some odd higher ohm loads
1LoudCelica Posted August 8, 2008 Author Report Posted August 8, 2008 i can get a 3 ohm load correct? least his was what I was told.
assman Posted August 8, 2008 Report Posted August 8, 2008 if you can get a 1.3 load then you should be able to get a 2.6 Assman IdustriesFear The DuckTeam Notoriously Loud Mafia
1LoudCelica Posted August 8, 2008 Author Report Posted August 8, 2008 if you can get a 1.3 load then you should be able to get a 2.6 that would work then, the amp I was planning on using is 2 ohm stable
Forevrbumpn Posted August 8, 2008 Report Posted August 8, 2008 I would just assuming wiring 4 subs or 6 subs at a time... see what numbers you can get with 4 and then 6 subs and then run them in banks of 4 or 6 that would be like 0.5ohms 4subs 1.33 6 subs ser/parr 0.33 parr 2.66ohms for 3 subs ser parr I dunno, thats how I would look at it guess finalized that ends up being 1.3/2.6 0.6 sure better numbers will be seen with more amps, 2 amps or 4 amps I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
