07sOnAtA sp.ed Posted August 12, 2008 Report Posted August 12, 2008 1) What is meant by the term "Flooded" Battery? 2) Why do all the car audio dealership tell me not to mix car battery companies. they make it seem like its so bad, and it can create many problems, but i see alot of people doing it on here all the time. ex: and optima upfront and a kinetik in the back CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
wL<3bass Posted August 12, 2008 Report Posted August 12, 2008 1) What is meant by the term "Flooded" Battery?2) Why do all the car audio dealership tell me not to mix car battery companies. they make it seem like its so bad, and it can create many problems, but i see alot of people doing it on here all the time. ex: and optima upfront and a kinetik in the back Different floating voltages among other things. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
07sOnAtA sp.ed Posted August 12, 2008 Author Report Posted August 12, 2008 how is relevant? i really dont understand much when it come to batteries and electrical CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
mrrairai Posted August 12, 2008 Report Posted August 12, 2008 1) What is meant by the term "Flooded" Battery?2) Why do all the car audio dealership tell me not to mix car battery companies. they make it seem like its so bad, and it can create many problems, but i see alot of people doing it on here all the time. ex: and optima upfront and a kinetik in the back 1) Flooded is your average lead acid battery. 2) You can mix different battery companies as long as the batteries are the same type. For instance don't mix a flooded die hard with an AGM Powermaster. IMO I like to keep the same type of battery (brand and size) because it looks better!!! Member since 25 Jun 2006 2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
07sOnAtA sp.ed Posted August 12, 2008 Author Report Posted August 12, 2008 Different floating voltages among other things. 1) Flooded is your average lead acid battery. 2) You can mix different battery companies as long as the batteries are the same type. For instance don't mix a flooded die hard with an AGM Powermaster. IMO I like to keep the same type of battery (brand and size) because it looks better!!! gotcha. thx for the advice CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
MECHMAN Posted August 13, 2008 Report Posted August 13, 2008 1) Flooded is your average lead acid battery. 2) You can mix different battery companies as long as the batteries are the same type. For instance don't mix a flooded die hard with an AGM Powermaster. IMO I like to keep the same type of battery (brand and size) because it looks better!!! +1. Most AGM batteries will rest at close to the same voltage. Powermaster has the highest resting voltage that I've seen, but only by a couple tenths. Flooded means that is is filled with electrolyte suspended in water. AGM means that the electrolyte is suspended in a silicate jelly, then soaked in fiberglass mats. Don't waste your time with Flooded batteries, AGM's are so common nowa days, and they perform so much better. 1-888-MECHMAN www.Mechman.com [email protected]
