honda Posted August 20, 2008 Report Posted August 20, 2008 I wanna upgrade for more power but right now I'm already pushing my 2006 Accod's stock alt to the max running three amps. I'm running 400Wrms to mids/highs and 1200wrms (AQ1200d) for my subs. I am planning on getting the AQ2200d or something with similar power. But first I thought I'd shop around for high ouput alts for my car. I called a bunch of HO alt manufacturers (exessive and ohio) and they told me that they don't have HO alt for my car cuz it uses the denso "hair pin" stator. So what are my options out there if I wanna run bigger amps? Any shop out there that makes HO alt of this kind? if i can't upgrade my alt, will upgrading batts be enough for the AQ2200d along with my amps for mids/highs? thank you My Soundz: '06 ACCoRD Diamond Hex (front)........................Diamond 2ch x 100Wrms............................Ought-guage Power wire and BIG THREE Diamond 6x9 (rear deck).................AudioQue AQ1200d @ 1ohm........................MTX re-Q (sound processor for stock HU) CDT tweets (rear doors)..................Alpine 4ch x 45Wrms.................................Clarion 7band EQ TWO Diamond D6 12" DVC 4ohm Coming soon upgrades: Batts dynamat trunk kit
Shinju Posted August 20, 2008 Report Posted August 20, 2008 I wanna upgrade for more power but right now I'm already pushing my 2006 Accod's stock alt to the max running three amps. I'm running 400Wrms to mids/highs and 1200wrms (AQ1200d) for my subs. I am planning on getting the AQ2200d or something with similar power. But first I thought I'd shop around for high ouput alts for my car. I called a bunch of HO alt manufacturers (exessive and ohio) and they told me that they don't have HO alt for my car cuz it uses the denso "hair pin" stator. So what are my options out there if I wanna run bigger amps? Any shop out there that makes HO alt of this kind? if i can't upgrade my alt, will upgrading batts be enough for the AQ2200d along with my amps for mids/highs? thank you From my research for looking at Alts for my Scion and comming across several forums with Toyota and Honda mixed, Seems like alot of honda owners just get a second H/O alt with their Stock Alt.
MECHMAN Posted August 20, 2008 Report Posted August 20, 2008 From my research for looking at Alts for my Scion and comming across several forums with Toyota and Honda mixed, Seems like alot of honda owners just get a second H/O alt with their Stock Alt. Making a bracket and adding a seccond alt would be the best option. 1-888-MECHMAN www.Mechman.com [email protected]
honda Posted August 20, 2008 Author Report Posted August 20, 2008 What kind of shops does this kind of job? (as far as fabricating brackets and adding a second alt for dual alt set up) Where do I go? also, how bad will two Alts affect my MPG and horsepower? (This is my daily driver car which is why I'm asking this.) My Soundz: '06 ACCoRD Diamond Hex (front)........................Diamond 2ch x 100Wrms............................Ought-guage Power wire and BIG THREE Diamond 6x9 (rear deck).................AudioQue AQ1200d @ 1ohm........................MTX re-Q (sound processor for stock HU) CDT tweets (rear doors)..................Alpine 4ch x 45Wrms.................................Clarion 7band EQ TWO Diamond D6 12" DVC 4ohm Coming soon upgrades: Batts dynamat trunk kit
sully Posted August 28, 2008 Report Posted August 28, 2008 Call a local Machine Shop or Hot Rod shop, they can fab something up and make it with a CNC. If there is not one available online maybe you could start selling them since the Machine shop will keep the specs in the computer and be able to give you as many as you want. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
