Extreme Groundpounder Build Up. Got Steel?(new Pics/doors Started 10-23-2k8)
Is it warping from all the heat and the paint from the heat
Im not worried about the paint at all, but if you look at the door gaps the car seems to be sagging in spots, I need to raise the car up off the ground, Im kinda worried I might kink some body parts, I guess well find out in the next week or so.
Well David...ya know what that means......All the more reason to weld the back doors shut :unsure:
I have thought about that, I dont think Im good enough with the mig to do that kinda work myself.
meade and I discussed some ideas yesterday on how to fix it, its gonna be tricky I think.
I have got to say awesome work on this build. Best two hours I've used ever used up while at work. Keep the pics coming. Hope you and Steve can fix the sagging.......
2003 Dodge Ram QC 4.7, 3/5 Drop, 22's, Kenwood Excelon x792, 6x9,and 6.5, Rockford 25 to Life Power 1000, RE MX 15, Stinger 1/0 and Big 3 all soldered, Interstate Megatron +, 160A Factory Alternator, MLA Module
Build Pics
thanks man, the car has deffinitly changed alot since I started this thread heh.
yeah I hope we can fix it too, we have a few good Idea on where to start, gonna be tricky for sure.
If you cant fix it then you could just weld it shut and have an extreme vehicle
wow all I got to say good work
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
its allready an extreme car, because of the roof strengthing in front of the b-pillar
damn david... it is starting to come together.. you know you wont have to do much work to get that jetta to lay frame with all that weight in it :) a car layin frame is sexy :wub:
what are you going to use to cover up the steel?? mdf or sheet metal?
IM A LOW LIFE SCAMMER SO I WAS BANT....TEH HAMMA is NOT my friend
it would cost thousands more to make this car lay frame, the front end is the problem because you cant make the top strut mount any taller, you would have to make your own suspension from scratch, I dont have that kind of money.
the steel will be covered with Baltic birch.
  • Who's Online   0 Members, 0 Anonymous, 3345 Guests (See full list)
