(DC AUDIO) BMW E36 Trunk Build (New Build, Page 11)
Thanks, I layed the first glass last night... i'll add some pix tonight... oh, also, how many layers do i need to do before i can take it out of the trunk?
Id say at least 2 layers of glass before you can take it out the trunk.
This way it is all sturdy and wont crumble when you take it out.
Then once you have it out, id put a few more layers on it.
Ive never had to glass the trunk well before, but from doing door panels, I noticed you want your mold to be stiff before you go and try movning it around, otherwise you may chance warping your part and you might not notice it til you test fit and it wont site the same as it did before.
Really depends on "how you glass"....
Are you starting with the woven mat, and going over it with chop mat?
Are you starting with chop mat?
Using it as it comes in sheets or pulling it apart?
I personally lay some resin by itself 1st so the liquid can really get in all the lil cracks and while it's still wet start adding woven mat that will get fine detail like that...and keep wetting the brush with resin to really "sandwich" the glass in between 2 layers of resin....OR use chop mat that has been pulled apart. It's tougher to work with/control and you will likely need to sand it between layers to get rid of "pokers" or singe strands of glass that hardened like needles....Use a 1" or so brush to "paint" resin over the top or more to the point/more importanly TAP it in...imagine BOB ROSS, the Hippy painter guy that liked to paint trees....he would use the tip of the brush and just grab some paint, then tap it into place to make his trees/bushes/etc..you wanna do the same but with resin and make sure that as you tap tap tap you get all the air bubbles out. The most solid layer you can get will the strongest.
I would do at leat 3-5 layers of chop mat b4 I try to pull it out...regardless of if u layed some woven mat too unless you used a shitlad of it..that stuff is pretty thin- which is why it grabs details so well...otherwise, if it adheres to the metal underneath. you can crack or warp the tub when you pull it...And try to work your way around the edge/perimeter if you can to free it up gradually rather than yanking on one spot and possibly cracking it.
I make mine strong enough to stand on WITHOUT mdf bracing...then I add bracing.
Good luck meng.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Good luck meng.
The Project!!
1954 Trunk Build
http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/
The Daily!!
Head Unit: Alpine 9883
Subwoofer: 2 12's DC Level 4 XL
Amplifier: New DC 3.5 K
Rear Center Console: 1 8' DD 1508
Amplifier: Rockford fosgate 500
Mids and Tweets: Beyma tweets
e36 Trunk/Subwoofer Build
http://www.stevemeadedesigns.com/board/ind...showtopic=27903
Thanks again fellorz! I got about 3 layers and i was finally able to yank it out! A couple more layers to go! but right now, Lsn, i am using the 1.5 once chop mat...
Dammnitt! I am all sticky!! http://www.stevemeadedesigns.com/board/public/style_emoticons/default/mad.gif
Posted Image
Posted Image
Posted Image
The Project!!
1954 Trunk Build
The Daily!!
Posted Image
Posted Image
Posted Image
Cute slippers.
I would put it back in and start adding more glass.
Cute slippers.
Cool, will do!! I need to run to the store and buy more resin.. i'm out.. :spiteful:
The Project!!
1954 Trunk Build
The Daily!!
scribed
what do you mean? :unknw:
The Project!!
1954 Trunk Build
The Daily!!
yeah...means i am tuned into this thread...so far so good.
Oh, cool...
The Project!!
1954 Trunk Build
The Daily!!
