David Posted January 7, 2007 Report Posted January 7, 2007 the 1206 d makes 1200 @ 1ohm I had this amp. Quote
Guest Nismofreak Posted January 7, 2007 Report Posted January 7, 2007 My plan was to use 0 guage wiring from the battery to the second battery and fuse between them. Then use a fused distubution block from their use 2 guage wiring to each amp. Can't wait. The 250 amp alt will be powerful enough. ;D Quote
Dale Posted January 7, 2007 Report Posted January 7, 2007 My plan was to use 0 guage wiring from the battery to the second battery and fuse between them. Then use a fused distubution block from their use 2 guage wiring to each amp. Can't wait. The 250 amp alt will be powerful enough. ;D If you are going to go ahead and use a fuse between 2 batteries, then I suggest you use 2 fuses. Each within 18" of either battery. Remember in that situation current can flow both ways and one fuse is not enough. Quote
Guest Nismofreak Posted January 7, 2007 Report Posted January 7, 2007 Why two fuses? I'm gonna put a fuse between the two batteries. Quote
Slinky Posted January 7, 2007 Report Posted January 7, 2007 Idont think you have to put a fuse there. unless that helps with not drawing so much current it drains the battery? i dont know. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Guest Nismofreak Posted January 7, 2007 Report Posted January 7, 2007 Well I'm gonna do it if something goes wrong. I don't wanna burn my equipment. So I'm gonna have it for a emergency. Quote
Slinky Posted January 7, 2007 Report Posted January 7, 2007 Well I'm gonna do it if something goes wrong. I don't wanna burn my equipment. So I'm gonna have it for a emergency. sounds good. i guess you can never have to many fuses! Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Guest Nismofreak Posted January 7, 2007 Report Posted January 7, 2007 sounds good. i guess you can never have to many fuses! Very true Quote
Slinky Posted January 7, 2007 Report Posted January 7, 2007 its better a 2 or 3 dollar fuse blowin than ruinin a high dollar battery. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Guest Nismofreak Posted January 7, 2007 Report Posted January 7, 2007 Your correct Noobster.j/k Quote
