"sleeper"(update Pics March 27)
that thing is ridiculous.
but i think im gonna copy your seat setup there when i finally get to build my 86
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
remember that the tahoe/yukon seat is a LOT thicker than the factory gm so be prepared to sit high and close to the wheel, i have my wheel in full raised tilt to get in the truck, got used to it though. good luck
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
Your build gave me and idea but im not to forsure how it would work. its and addaptation of ur blowthrough but totaly in the cabin. dont recall if you designed ur enclosure but here is my idea. Hoping you might be able to give me some insight.
http://www.stevemeadedesigns.com/board/ind...showtopic=41658
A New Begining Starting Over
2003 F-150 extended Cab
Head unit: Pioneer 880
Speakers: JBL 6.5 comps and 8's in doors
Amp: JBL 100x4 & JBL GTO700.1
Sub Amp: ?
Subs: Possible 4 SX 15's or 2 SX 18's
Box:18-20 sq ft @ 30
Batts: Still Need
alt: mechman still to order
Wire: Lots of 1/0
almost identicle to the one i drew up, but i would plan on bringing up your rear port tuning a few freq unless you want to play in the mid 20's. design does good but use a loadind wall for the front subs to balance them out from the rear ones.( there is alittle bit of unloading in mine, i need to squeeze up my cab port i little) good luck and post pic oh yea and buy some dc audio
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
Im not for sure on how many cube and what tuning to use for the rear chamber? that design wasnt tuned ur anything just sketched up with my outer dims. as for a loading wall, what orentation would work best a flat wall like i have in the sketch or a "V" shaped wall that would sit in the mouth of the enclosure? ill draw up a few more detailed sketches that might make my idea clear
By the way your truck is just nasty and I would get some DC but got to do with what I can afford atm
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
did some testing tonight and was a little dissapointed ... i am still peaking at 26hz with just under a 152 (after 10 mins of testing) but i am only hitting between 148 and 150 from frequencies 45-80.....with my changer skipping :spiteful: maybe ill unmount that thing and test again and mess with my eq to try to get a 50 on every bass note some other time
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
  • Who's Online   0 Members, 0 Anonymous, 3062 Guests (See full list)
