bigeasy79 Posted January 6, 2007 Report Posted January 6, 2007 http://i120.photobucket.com/albums/o169/bi...01/12FIBTL2.jpg do the corners have to rounded like that or could i just put a straight piece of wood across the corners
AI James Posted January 6, 2007 Report Posted January 6, 2007 its nicer like that but you can 45 some flat wood in there just fine
bigeasy79 Posted January 7, 2007 Author Report Posted January 7, 2007 whats the best way to do the rounded corners
bigeasy79 Posted January 7, 2007 Author Report Posted January 7, 2007 should it be louder or sound better with the rounded corners insted of just a piece of wood
Pokey Posted January 7, 2007 Report Posted January 7, 2007 Would be smoother if you glassed it...less air turbulence...possibly a little louder, but may not be enough for you to hear it.
Ernesto Posted January 7, 2007 Report Posted January 7, 2007 Would be smoother if you glassed it...less air turbulence...possibly a little louder, but may not be enough for you to hear it. You won't notice it by ear.
David Posted January 7, 2007 Report Posted January 7, 2007 the air-flow benifits form the round corners, there are a few differrent ways to it. PVC cut into qtrs and glassed in, I have seen someone use shaping foam then glass that or you can use wood/w 45 degree angles. to get it perfectly round takes time and work.
