I noticed that the cone was getting a little warm after playing for a few minutes. I did not smell anything burning. I use a Hifonics BXi2608D, the amp gets a little warm too but not now where hot so I think that is normal. But is this normal for high power subs? Any help would be great.
Eclipse
Hifonics
Alpine
Kinetik
Optima
Excessive Amperage alt
IMO there is no way of helping you without more info.
Woofer specs.
Box specs.
Electrical Upgrades if any?
need more info
Woofer specs.
Box specs.
need more info
Here are the specs of the sub http://www.maxxsonics.net/manuals/hifonics...er%20Manual.pdf
Box is 3.49 cu. tuned to 36 hz
optima yellow top d35 under hood, big 3 done, 0/1 wiring single run, 8 gauge wire for the sub. And 180 amp alt.
Edited by truck_buster23
Eclipse
Hifonics
Alpine
Kinetik
Optima
Gains set correctly with a multimeter?
Have you checked your sub resistance at the amp (speaker wires disconnected of course)?
No I did not check the resistance bit will.
wired in parallel hopefully?
dmm... did you set the ac voltage to 49v w/50hz test tone @ 3/4 volume?
the brutus amps do get warm... especially at 1 ohm
I set it too 48v but it's too much for the sub in this box I think I had to back the gain off.
Eclipse
Hifonics
Alpine
Kinetik
Optima
idk you may be clipping the sub even with the electrical upgrades you have.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Yeah I was thinking that too. My voltage is between 12v-13.8v, I need to get my kinetik in.
Eclipse
Hifonics
Alpine
Kinetik
Optima
my dmm leads must be bad it reads all over the sub sounds fine and plays loud and I double checked the wiring and it's wired for 1 ohm. the amp and sub are brand new so maybe it's clipping because I dont have enough voltage.
Eclipse
Hifonics
Alpine
Kinetik
Optima
