Like the title says I need some info on a Digital Audio HDC-1604. What are the ratings? An yes people, I have searched on line first... their website must be down or something and I did a search on here with no luck...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
doesn't seem like a legit part number, I googled it, and nothing
something about the number is wrong
Thats the number off of the amp. Must not be popular....
I do box designs.
dislexic are you? lol
http://www.emcaraudio.com/Online%20Catalog...tal_audio_2.htm
the part number prefix was just a little backwards
DHC not HDC
Common Features
PWM MOSFET Power Supply
THD: 0.02%
S/N Ratio: >100dB (+/- 1dB)
Frequency Response: 10Hz - 40KHz
Variable 18dB Hi-pass Crossover: 50Hz -750Hz
Variable 18dB Low-pass Crossover:
50Hz - 120Hz
Bass Boost: 0 - 18dB Variable Sub-Sonic Filter: 20Hz - 50Hz
4-way Protection Circuitry: Thermal, Short Circuit, Overload & DC Offset
Cooling Fans
Red Illuminated Logo
Brushed Aluminum Finish with Diamond-CutHeat sink
1/2/3 Channel Operation (2 Channel Models)
2/3/4 Channel Operation (4 Channel Models)
1 Channel Operation (1 Channel Models)
4 Gauge Power Connection
Item Features
300 watts x 2 @ 4 ohms stereo
600 watts x 2 @ 2 ohms stereo
900 watts x 2 @ 1 ohm stereo
1200 watts x 2 @ 1/2 ohm stereo
2400 watts x 1 @ 1 ohms mono
DHC not HDC
Sometimes it happens. Sorry about that.... That would be a good reason why I couldn't find it
Edited by banginAltima
I do box designs.
Common Features
THD: 0.02%
50Hz - 120Hz
Cooling Fans
Item Features
what are the odds of it actually doing 2400 watts???
I do box designs.
email them... i have no idea plus there is no fuse rating or pics of internals
it is a highcurrent amp not class d so as long as you can feed it lots of amperage...
