SO heres the deal. I bought a new custom made 200amp Alternator for my car. I also big the big 3 with a new deep cycle battery put in. The probelm is that my lights are still dimming, not only when the bass hit but when i do anything that uses power. When i try to roll up my windows my lights dim, the headlights and the overhead light in the car. I dont know why its doing this but what could be the problem that my lights are dimming this much? because it is very noticable when they do dim.
2 things could possibly be the issue:
(1) Get a DMM and first check to see if the alt is putting out the proper amount of voltage (I idle @ 14.5v, and 1800+RPM's im at 14.8ish) Your alt might not be putting out anything, so you might be running off striaght battery 12.6v, if so NOT GOOD!
(2) Some high amp alts (200+AMPS) dont put out much at an idle speed (Some do, and some dont) so try this: Hold a steady rev of about 1500-2000rpm and try your light to see if they still dimm, if they still do, I think your issue may be what I stated in #1..... Also check the obvious....Fuses, fusible links, etc.....
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Yup, check the voltage at idle. It could be low to start with, or the higher voltage at idle might just make the headlight dimming more pronounced. A DMM voltage measurment at the battery will tell the story.
i have doubled checked all the connectons. those arent the problem. no fuses are blown. I am going to buy a DMM today to check the voltage today.
Well, have you got your voltage readings yet?
i just checked the voltages. and at idle it was 14.1 and at 2500 rpm and any other rpm its was 14.1 the same thing.
Ok, your idle is 14.1V, but I bet you have low "AMPS" at idle. I'll bet that even though your still @ 14.1v @ 2500, your headlight will dim less, or not at all, cause @ 2500rpm, you alt is feeding some nice amperage.
My headlights and dash dim at any rpm level. I have a 225 amp alt from EA, the big 3, and an hc2400 in the spare tire well, and my lights dim when the bass hits no matter what my rpm's are at. I have the mla module and never drop below 13.8 volts at full tilt with rpms at 2000. They still dim.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
  • Who's Online   0 Members, 0 Anonymous, 931 Guests (See full list)
