94 Civic Spl Enclosure Trunk Only
SPL KID
The equipment is as follows:
2) Digital Designs 3512
1) Audio Pipe AP3001D
pioneer DEH-5600
94 civic dx 2dr
Current config yeilds 149 db + on Tones. And 148 flat center of Dash and 148.7 on music right corner windshield.
Posted Image
I need to get my pressure up more! Car doors are the only deadened area (with peel and seal) with light coating of Fiber Glass on rear deck and trunk lid.
Any Ideas with designs and such will be greatly apprieciated.
NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! TEAMHIGHX-CURSIONsig-1.jpg
Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
any pics?
6 cu FT box no pics at the moment.
that isnt a bad score out of a trunk, especially with type r's. could upgrade the subs and power to gain a few db's.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
no room for subs and port back that I can figure not using what i have now. I plan on cutting the old wheel well out and putting stronger steel and rhino lining the whole rear end. I may have room for subs back and port back then. If I can get a good enough enclosure config I might build something that can be put in while the well is out and then put the steel back in around it like they would do the SPL vans. I'm trying to keep use what i got for now.
How's the access to the trunk with the back seat folded?
Maybe a big 6th order bandpass with 2 subs on each side firing into a common chamber in the middle with 2 6" aeros (or a huge slot port) venting this chamber forward through the arm-rest gap, then seal the trunk. 1 or 2 4" aeros per side in the side chambers so you can tune it easily.
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 2010 Guests (See full list)
