K.
Soo..
One of the hallway lights at my house..
Will randomly turn off, than back on.
Started about a year ago when I started to play my sub loudly... Oops.
Haven't gone into the attic..
Every bulb we've put in there does the same thing.
:threadjack: i think i broke a water pipe above my bathroom a few months ago cause it started to leak like 10 minutes after i finished beating :/threadjack:
but its probably a bad ground, and it loses whatever little connection to ground it has when it rattles from the sub's
Edited by Krannyman92
OH SHIT!
I'd be fucking DEAD if that happened...
some girls at a local sorrority called me to fix the same thing, hallway dome light flickered if someone ran up the stairs. i took it apart and it looked like one of the soldered on connections to the socket was bad, i kinda just bent it in with a screwdriver and called it a day cuz im too lazy to play electrician in the middle of a friday afternoon, works fine now, no more flickering.
if its the kind they had, where its a base and a plastic socket mounted parallel to the cieling where the bulb goes, try wiggling it.
Team DC
there are a few things that could be the problem,
1. bad switch or going bad =$.50 replacemt
2. bad light assembly and just needs to be replaced due to age and over heated internals $7-15.00
3. rodent has half way chewed thru the wires $take loan out and let the pros deal with that crap lol...
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
okey... sounds good.. cept for the loan part... shit credit ftl
lol ghosts....
if you have a decent knowladge of elec then if it does need the wire replaced its not hard to do or expensive, maybe 35-40 dollars for a roll or romex and junction box (if you have to splice into the wire) and shouldnt take but maybe a hour or 2 to complete, but i would do the switch first and then the fixture then the wire when all else fails
