im havign some problems getting power to my amp. The situation is i replaced my old wiring the power and ground and remote. the remote wire stayed in the same spot nothing changed but the power cables went to 1/0. So i set my fuses up and ran the wires back to my amp. the power like flashed on for half a second and then its gone. Any ideas on why there is no power going through the 12 volt cable
system hifonis brutus amp
2 FI 12's
do you have the amp wired in at a 1 ohm load?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Ummmmmmm, I think you burnt your stuff if yousay power surged for half a sec then quit....
You're saying that now there is no power coming from your 1/0 cable from the battery to the amp??
If that's the case, it can only be your fuse, ground, or battery if you ran them straight through.
If everything else still works, like your deck and the rest of your car, eliminate the battery. That leaves fuse, bad ground, or a bad power connection.... That's all I got.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
check fuses on amps and under car dash to make sure its free of dirt or if its broke. are u getting the right amperage to the amps
Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
well the amps not fried, like is there a possibility te amp wont come on due to a pinch in the remoite wire and if that has happened can i replace the remote wie with like any type of wire of does it have to be of a special kind
wire is wire is wire...aside from strand count and such all wire is the same more or less. doesnt matter what color the jacket on the wire is, its still the same inside. as long as u use about the same gauge for the remote wire then your fine.
its gotta be:
1. power cable and fuses
2. bad ground
3. bad remote wire
4. bad amp/fuses in amp
5. low voltage (doesnt seem right in your case though)
...now start troubleshooting
i likes me some audio stuff...
