Nickvb6 Posted October 8, 2008 Report Posted October 8, 2008 Ok i have had a few people tell me this they say dont run a ground from your front battery to the back batterys because you will get sound from the motor is this true should i only run power wire and just ground the batterys in the back to the amps?
anti.commander Posted October 8, 2008 Report Posted October 8, 2008 The only way i know that one can get feedback is if they run the RCA cables next to the power wires. I beleive steve has grounds running to the front.
wasted ink Posted October 8, 2008 Report Posted October 8, 2008 either way works, you can save money by finding a good ground near the bat in the back Wasted, Incorporated Up Front: Optima Yellowtop HU:Pioneer Avic N1 w/ 2007 upgrade Front Stage: MB Quart 6.5 comps Rear Fill: Infinity Reference Sub Stage: RE MT 18 Sub Amp: Undecided Sub Enclosure: 5.5 cubes tuned to 33hz Absolute Terminals SkyTec 5100RS 2-Way LCD Pager KnuKonceptz Wire My Build Log
audiofanaticz Posted October 15, 2008 Report Posted October 15, 2008 not true at all. Adding a run of negative cable from front to back is just lowering any resistance. if runnning the ground wire from front back would cause sound interference, then your body of your car should do so too, which it dont. Just about every piece of metal on your car is grounded out.
Neel Posted October 19, 2008 Report Posted October 19, 2008 negative on the interference being caused by adding a ground wire.... i wouldn't even bother doing a separate run for your ground unless your running a good amount of power.... Too Much Stuff to list .
