What is the difference (in terms of power demand) between running two subwoofer amps at 4 ohms bridged mono each vs. running one large amp at 2 ohms bridged mono, given that the RMS wattage output is the same?
Would either configuration draw less power from the car?
**EDIT: Just thinkin....I have no plans....yet!
Edited by ptcary
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
I would think.... if it takes XXX amount of power to make XXX watts with one big amp. I think generally it would still take the same amount of power to two amps to make the same watts.
It may all depend on which ohm load is more efficient for the amp.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
i think it also depends on how efficient the amps are...and which amps ;)
I would bet that one amp would be more efficient...
Eclipse cd7000
I guess efficiency is the question.
I want two amps that can do 1200 watts each @ 4 ohms, or one amp that can do ~2400 watts mono @ 2 ohms.
Anyone want to comment on some low to mid priced amps that are very efficient?
(I am headed into the SMD search engine).
Edited by ptcary
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
Why are you wanting to run a high ohm load? What subs do you have and how many?
I do box designs.
i think ease of install would be the biggest factor...also once installed, the ease of set-up would also come into play. Gain matching multiple sub amps can be a pain (unless its RF T-series blah blah blah :D :D).
anyway you get what im tryin to say im sure :)
Follow my Tweet (Twitter)
I have 8 12" subs. 2 sets of 4 wired together, 4 ohms each.
So I want two 4 ohm amps, or one 2 ohm amp.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
I am thinking 2x Crunch GP2500D, they are supposed to be ~1250 watts RMS.
I need to learn more about how to rate efficiency and look at other comparable amps to this one, but you guys know I am a Hifonics addict.
Edited by ptcary
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
Yeah, next time around, i plan to stack 3 amps in one rear footwell with 2 fans on them. Easy to build rack, and very easy to adjust them! :D
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
  • Who's Online   0 Members, 0 Anonymous, 7224 Guests (See full list)
