GORILLAslap Posted October 18, 2008 Report Posted October 18, 2008 i turn lp an hp knobs all the way down?? starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
Decaf Posted October 18, 2008 Report Posted October 18, 2008 geezzus lpf should be set at 80-100hz hpf wont matter if u select lpf on ur crossover switch on the amp, which im assuming it has lpf = everything below that chosen note passes thru hpf = everything above the chosen note passes thru
GORILLAslap Posted October 18, 2008 Author Report Posted October 18, 2008 geezzuslpf should be set at 80-100hz hpf wont matter if u select lpf on ur crossover switch on the amp, which im assuming it has lpf = everything below that chosen note passes thru hpf = everything above the chosen note passes thru and a crossover swith is the bass knob thing right??? fuck u i kno im dumb thats why im askin for help starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
bumpinprix Posted October 18, 2008 Report Posted October 18, 2008 you seriously need to go to the12volt.com and bcae.com and read for a few days.
Namosh Posted October 18, 2008 Report Posted October 18, 2008 No, the bass knob isn't the crossover. The lp and hp are your crossover settings. My Ram Quad Cab Blow-through
Torres Posted October 18, 2008 Report Posted October 18, 2008 ima repeat myself... http://www.bcae1.com
