My Sub Ohm Load
scfaust
i wanted to know whats the deal i have 3 dual 2 ohn alpine type r subs if i wire em in parallel/parallel (pos to pos neg to neg then pos and neg to amp) i only get a .9 ohm load. if i run in series/parallel i get over 2 ohm close to 3. i dont understand i thought i shoud get 1.33 series/parallel. and way under 1 like .5 or less in parallel/parallel can any one tell me why and is it ok safe to run parallel/parallel
It sound like you're getting extra resistance which I guess is oming either from your multimeter or wiring. Check each coil individually, then check each sub after wiring the coils together, then check all subs wired together.
A sub with '4 ohm' impedance doesn't always have a DC resistance of 4 ohms.
Some subs will specify a 'dcr' specification which is the true DC resistance - in many cases it's a lot lower than the stated impedance.
10.x volts fo' life!
Yup some are as low as 2.8 and other are 3.2-3.4.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
  • Who's Online   0 Members, 0 Anonymous, 439 Guests (See full list)
