How I Solder 0/1 Gauge Wire
What is the model number of the torch you got at Harbor Freight?
x2
Is there a way to get the burn mark off the terminal?
Nice vid by the way :)
Eclipse cd7000
BUMP, does anybody know the answer to my post right there? ^^^^
Thx :D
Eclipse cd7000
Hmmm. Is it bad if I add the terminals to my 0 gauge by crimping and than a few weeks later decide to go back and add the solder?
  • 11 months later...
  • 1 month later...
So do I understand right? You must use rosin core solder when doing this? If so that explains why when i tryed using acid core it did not work!
  • 2 months later...
Another thing I personally like to do is to wrap a wet rag around just underneath the terminal. Basically at work unfortunately we don't have any small torches so we need to use the big fatboy ones. The wet rage below the terminal prevents the solder from running down the wire too far and making it all stiff. Because the torches we use heat a lot more, the rest of the wire gets really hot too so the solder runs down. So yea, if you have nothing but a big torch you can wrap the wire up haha.
Just thought I'd add that for the hell of it. Good vid man.
  • Who's Online   0 Members, 0 Anonymous, 1381 Guests (See full list)
