jesseanson Posted October 21, 2008 Report Posted October 21, 2008 do you think one optima yellow top up front a 200 amp alt and a powermaster d2400 in back will be enough to power 2 RF t1500-1bd amps? 2004 gmc Yukon 270 amp mechman alt. 1 odyssey PC1500 up front 6 kinetik HC2400's in the back 2 18" BTL's fully loaded 2 saz-3500d's strapped 155.7db @ 38hz sealed MY YOUTUBE!!!
Nightshade Posted October 22, 2008 Report Posted October 22, 2008 You should be fine with that kind of battery power. The D2400 alone offers 87ah and over 2000 amps. The yellow top will be good for the vehicle's accesories and the D2400 will be fine for the two RF amps as long as you aren't going crazy for extended periods of time. Otherwise I'd say move up to a D2700 or even a D3100. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
dmanson Posted October 22, 2008 Report Posted October 22, 2008 You should be fine with that kind of battery power. The D2400 alone offers 87ah and over 2000 amps. The yellow top will be good for the vehicle's accesories and the D2400 will be fine for the two RF amps as long as you aren't going crazy for extended periods of time. Otherwise I'd say move up to a D2700 or even a D3100. i'm with him 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
raytard Posted October 22, 2008 Report Posted October 22, 2008 you cant go too big and its basically only a few bucks to step up, unless space is an issue, use the biggest one you can fit back there Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
jesseanson Posted October 22, 2008 Author Report Posted October 22, 2008 you cant go too bigand its basically only a few bucks to step up, unless space is an issue, use the biggest one you can fit back there yeah moneys not the porblem its that i have no room left haha i have 11 inch length and 8 inch width left in the back of the truck but of course the d2700 is 12 inch length haha. 2004 gmc Yukon 270 amp mechman alt. 1 odyssey PC1500 up front 6 kinetik HC2400's in the back 2 18" BTL's fully loaded 2 saz-3500d's strapped 155.7db @ 38hz sealed MY YOUTUBE!!!
raytard Posted October 22, 2008 Report Posted October 22, 2008 you should be fine with a 2400, so dont fret too much about it. if a 27 or 31 would fit, i'd say just spend the little bit of extra cash and go that route, just for overkill sake, but a 24 should suffice, especially with a beefy alt Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
dmanson Posted October 22, 2008 Report Posted October 22, 2008 don't forget the MLA module 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
