12v/16v Question?
I have been thinking about getting 2 16v batteries for the rear of my car..The thing i was going to use the 12v side of the battery for connection to the front battery and to run the mids and highs amps and wat not then use the 16v side for the connection between the 2 batteries in the back and to power my hk401sx's(since they can take 17.xxv from the factory)
watcha guys think?
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
watcha guys think?
If you are reffering to 3-post batteries, they won't work like that. You would still need a 12 and a 16 volt alternator to charge them properly.
watcha guys think?
The whole reason why they made 3 posts was so you wouldn't need 1 or 2 step down modules to add to the expense and so you could only run one alternator if that was your choice. I have heard that from Kinetik tech support. Ask the manufacturer direct and they can probably guide you into the best set up for your situation.
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
