Box Problems
frkkevin
External Dimensions: 17x39x24
Daily port:
Vb = 6.29 cu.ft
Fb = 35 Hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 14 in
Wv = 4 in
Lv = 15 in
SPL Port:
Vb = 6.648 cu.ft
Fb = 41.98 Hz
Fill = none
No. of Vents = 1
Hv = 14 in
Wv = 4 in
Lv = 7.75 in
Now the problem I have is the port area, well the lack of.  :ranting2: All I can get is 56 square inches of port area. Think it will be alright?
Yea i know .. but there is no chance I can get it..  the subs themselves will take up 31 inchs of the box leaving 8 inches of workable room.. subtract 1-2 off each side to allow for clearance.. and im down to 4-6inch wide port.
if i can squeeze in  that 6 inch width i'd be on the money..  how bad do you think the port noise would be?  its not a horribly small port
pretty bad probably seeing as the ports only a lil over half what would normally be used
For the size of the enclosure it's a horribly small port.  I would try to find somewhere else to put the port, or go with something more manageably sized.  A proper box for smaller subs sounds better than an improper box for larger subs.
I'm just gonna make a 6" port .. some how.. some way.. I will get it.  Given that I'd have 84 square inches of port.  Now plotting the design in BBP6 I'm see a gain of 2.81dB / 51.70 Hz.  Does that seem right?
I'm looking for a 152dB but I'd be very happy with 150dB.
Can someone run through this and tell me what they think?  I'll be running two RE SX 15"s and two RE 35.1s.. so depending on how underated the amps are we are looking at 3000rms-3600rms,  they are rated 1500rms @ 1 ohm 12.6v volts but I've been told they do 3600rms on 14.4v.. so it depends on my voltage drop which will probably be bad lol.
Driver Properties
  Name:
  Type: Standard one-way driver
  No. of Drivers = 2
  Mounting = Standard
  Wiring = Separate
  Dual voice coils = separate
  Fs =  27.8 Hz
  Qms =  4.7
  Vas =  126.3 liters
  Xmax =  22 mm
  Xmech =  33 mm
  Qes =  0.38
  Pe =  1000 watts
  Qts =  0.352
  no =  0.688 %
Box Properties
  Name:
  Type: Vented Box
  Shape: Prism, square
  Vb =  6.5 cu.ft
  Fb =  41.98 Hz
  F3 =  36.97 Hz
  Fill = none
  No. of Vents = 1
    Hv =  14 in
    Wv =  6 in
    Lv =  13 in
  • Who's Online   0 Members, 0 Anonymous, 1351 Guests (See full list)
