Any of you who are running 6-10kW, what kind of upgrades did you do for power? I'm sure I'll be able to support one of my amps, but I'm worried about running two of them. These amps are power hogs but they perform very well otherwise...
I'm trying to run two MCD4KWs @ 1-ohm which should be about 8000 RMS. But according to tech support, they pull about 400A at full crank. I'm hoping to dampen that with a line driver but I'm still worried.
Do I have enough to power them as a daily driver? Or should I just use one for listening and both in comps (assuming I'm hitting numbers)?
-300A Iraggi
-(4) Kinetik HC2400
-(4x) 1/0 wires throughout
Need an install? Hit me up.
[email protected]
just my .02 but if the 4 batteries are in the back near the amps they should give you the current you need, but a second alt would be an excelent idea, since once those abtteries are drained down, you're going to be stuck with only 300a of current to recharge the batts and supply your system, car, lights, etc. If you plan on driving down the highway on blast, or letting it play close to max for extended periods, definately consider another alt
other than that, you should be fine
Team DC
Well guys I forgot to mention one thing... According to all of the ppl I've dealt with including Dom, it seems impossible to get another alt in there without extreme modification... So I'm kinda stuck with the extra alternator idea.
And yes, the power wires and ground wires from battery bank to amps will be < 12" long.
[email protected]
-300A Iraggi
-(4) Kinetik HC2400
moar batteries.
well since your topic title refers to 8000kw (8,000,000 watts) :hairtrick: :hairtrick: i'd say way more bateries and alts
That's what i was thinking... thatsalottapower!
Haha, I didn't even catch that, that's good. Alright. I guess I'll just try it out and watch my voltage. I figured more batteries would be what it took. Thanks for the help!
[email protected]
i think you need another alt and 1 or 2 more batts this is what id did to run my 4 amps for 30 seconds
each amp pulls 480 amps
why didnt you use buss bars instead of all the sections of 0guage and ring terminals?not knockin your work just asking.
and since you cant add another alt i would add a few more batteries at least
Well, I used buss bars in the front from the front battery and at the entrance to the bank in the back. I have a lot of tools and stuff flying around in there and I get really nervous with metal tools around those batteries. Buss bars make for easy accidents, but I have more buss bars on the way and that will be the final power upgrade before the amps get permanently set.
They are very convenient and worth it.
Edited by Neo_frog
[email protected]
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
