subs are much larger and heavier thereby designed to play low notes easier. the amount of power it takes to move a subs cone quickly enough for vocals is too much for the amount the sub is moving. therefore the coil will burn due to lack of cooling because the cone doesnt move enough.
plus it sounds like ass
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
well put...
NoFearX18 said:
trainman0978 said:
i think 8's are as big of a sub that will be able to handle vocals but still has to be playin bass to, just words wont work right, i got my 8's set on low pass but when i set em to flat they play vocals n bass just fine but if u cross em over to high it sounds like pure ass, only reason not to is like he stated cone moveing really slow creates backpressure in the former n alows air to flow threw but when just vocals(no bass) is played they will over heat, but most ppl will look at selinums thinkin there subs but there pa mids that dont move no more than 4mm period so there good for vocals, but if u play vocals and bass threw subs over 10'' the diff tones all over the place will make it work to hard n burn up, it will try to play low,mid, n high bass notes were its only susposto play low bass around 150htz down, so i wouldn't risk it thats what they got mids n highs for
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
plus break down the word...sub-woofer
sub-below
it plays below what a woofer plays...being bass
NoFearX18 said:
trainman0978 said:
Way too much moving mass = sounds like shit.
Size and excursion have nothing to do with it. Have you guys ever seen a 15" PA 'woofer' (probably playing up to like 1.5khz at least)
A lot of it is to do with the moving mass relative to the strength of the motor...
10.x volts fo' life!
the technical reason , is the voice coil acts as a natural cross over, the voice coil is an inductor, just like in a passive cross over, they are rated not just in Ohms, but in Milihenries, the higher the number in mH, the lower the frequency response
and the weight of the cone is another factor, but even if the weight of the cone was 1 gram, it will still have that natural 6db slope, or whatever it is
but the coil, and the MMS kind of work together on this, in there own ways
You asks and there you go.. You recieved lol
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
  • Who's Online   0 Members, 0 Anonymous, 2885 Guests (See full list)
