Which Sub/s Will Have More Spl?
jazza02
2 15's is real hard. My friend has 2 RE SX12's in a VT sedan, does 144.8 @ 36hz. Box is about 4 cubes with 1 6" aeroport, subs back ports back and some serious hackery in the parcel tray.
10.x volts fo' life!
Yeah well now i have nailded it down to either 2 12" SPL series Option Audio subs and a 3000wrms Option Audio amp
or
Either
2 12" soundstream SPLX subs and a Soundstream TRX2000D amp.
I am after number so what ever set up you think will get me the most numbers please tell me as i have had no experince with these brands.
australia03junehl4.gifCURRENT SET UP
Factory HeadunitGladen dual splits
Audio helon 4ch amp
Audio Helon 9kwrms monoBlock
2 15" Custom built Pap subs rated at 3kwrms each
The Option Audio '3kw' amp is the same as the Soundmagus amps, realistic power is 2.4kw without obscene amounts of distortion.
Well just for now i am going to go with a cadence Beast Master 12" SPL sub it's a 04 model and it's for sale on MEA. And i am thinking of getting either 1 amp and run it at .5ohm or get 2 amps and run them at 1ohm. But i have to see what i have to spend after i build the box and get the wiring. The guy who has it now was running it of 2 Cadence ZRS-8 1500 wrms amplifiers with a 4.5cuft box with a massive slot port tuned to 45-50hz. He told me if i can build a box and tune it to 55-60 he thinks that i would get high numbers. Here is the link to it so you guys can check it out. http://www.mobileelectronics.com.au/forums...howtopic=546566 . Tell me what you think of it ?
Audio helon 4ch amp
Well im just after a sub that can handle the odd comp and still be able to do well daily
So would you have box plan or anything that would be decent ?
also what did you think of the sub ?
Audio helon 4ch amp
well i would like some more input about the sub, See what people think about this sub and how is would preform
Audio helon 4ch amp
