Split9112 Posted November 1, 2008 Report Share Posted November 1, 2008 i am going to buy a amp with in like a week or two and which one would be better. i am planning on running two fi ssds and i did't know wat one would be better http://www.sonicelectronix.com/item_11752_...ch+P1400.2.html http://www.sonicelectronix.com/item_11671_...ch+P1500.1.html Live Fast Die Fun!!!! Use it or lose it Link to comment Share on other sites More sharing options...
97maxima Posted November 1, 2008 Report Share Posted November 1, 2008 1500 American Bass*DC Power Link to comment Share on other sites More sharing options...
dmanson Posted November 1, 2008 Report Share Posted November 1, 2008 10 potna and be sure each sub is a D4 so that you could wire each to 2 ohm and parallel them both to the amp for a final load of 1 ohm ....... use no less than 4 ga for the power/ground wires. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Split9112 Posted November 1, 2008 Author Report Share Posted November 1, 2008 10 potna and be sure each sub is a D4 so that you could wire each to 2 ohm and parallel them both to the amp for a final load of 1 ohm ....... use no less than 4 ga for the power/ground wires.well the subs are d1 Live Fast Die Fun!!!! Use it or lose it Link to comment Share on other sites More sharing options...
dmanson Posted November 1, 2008 Report Share Posted November 1, 2008 well the subs are d1\well you might want to get the 1400.2 then .......... run each D1 at 2 ohm each and then you can run each channel of the 1400.2 at 2ohm. you want to get the most out of the amp if possible. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Split9112 Posted November 2, 2008 Author Report Share Posted November 2, 2008 but with two subs i can wire them down to 1 ohm. or would the p1500.1 not be stable? Live Fast Die Fun!!!! Use it or lose it Link to comment Share on other sites More sharing options...
Chris from Mi Posted November 2, 2008 Report Share Posted November 2, 2008 I'd say neither, give those subs the power they deserve, maybe a crunch gp2500. or brutis 1206D Orion 2500D, Jbl Gto 75.4 Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids Alpine cda-105 optima up front Knu klm 1/0 Link to comment Share on other sites More sharing options...
reinke Posted November 2, 2008 Report Share Posted November 2, 2008 get the 1500.1 they will work at half a ohm but your electrical has to be good. ----reference's---- meade916 Link to comment Share on other sites More sharing options...
wL<3bass Posted November 2, 2008 Report Share Posted November 2, 2008 get the 1500.1 they will work at half a ohm but your electrical has to be good.He said the subs are D1......so please tell me how two D1 subs wire to a .5ohm load....? If your set on Crutch, get the 1500.1 and wired each sub in series and then parallel together for a 1ohm load. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
reinke Posted November 2, 2008 Report Share Posted November 2, 2008 sorry had to think about that one. wire it your way. ----reference's---- meade916 Link to comment Share on other sites More sharing options...
