Now maybe this is a dumb question, but because of the 'hot amp' problem I had, I'm wondering if it's legit...
Let's say we have two 1-ohm speaker loads and a 1-ohm stable amp...
Now the only possible wiring schemes would generally yield .5 and 2-ohm configurations..
If you were to just twist the positive leads together and the same with the negs, wouldn't the setup continue to be 1-ohm? That's what my meter is telling me, but I don't think that can be right. And plus when we did that with a 1-ohm stable amp, it got really hot after a short time.
I just wanna ask you guys to make sure I'm not crazy.
Need an install? Hit me up.
[email protected]
Two 1 ohm loads, paralled pos to pos and neg to neg?
Wouldn't that be a .5 ohm load on a amp that is only 1 ohm stable??
Did I read your question wrong? :unsure:
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
I am not sure, but do you basically have 2 sets of 16 subs 1 ohm per set? Paralleled together, then that is indeed a .5 ohm load and if that test amp you used can only do 1 ohm, then it would get really hot at .5 ohm.
If so...wire the two sets of 16 subs in series for a 2 ohm load and test them again.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
See that's just the thing.
First off, I'm sure my wiring is right. I have two leads coming from the box each being a 1-ohm load (per 16 subs). Yet when I tie them together on an amp or not + to + and - to - directly into the amp, they still read 1-ohm...
Now the only thing I could think of would be enough resistance across all 32 subs to add around .5 ohms to my reading...
I was confused for a while, but I think that's the case. I'll do some more tests. Amps should be in tomorrow for those watching.
[email protected]
Are the 10s D4 subs? If so I get .5 ohm load for 16 subs with a series/parallel config. Am I right, you have a set of 16 subs on a 4K, and the other 16 subs on the other 4K?
.5 ohm nominal on each amp with 16 subs
.25 ohm nominal on one amp with 32 subs
Both cases with D4 subs in a series/parallel config
With all the wire and connections made between them, I can see an increase in resistance with that your meter ''sees'' although DMMs average out what they read
  • Who's Online   0 Members, 0 Anonymous, 2504 Guests (See full list)
