so i need to make some major vibrations from a sub and i figured subharmonics would be a good way to do so. however i cant quite get wut im lookin for.
basically wut i want is a synthetic 15 or so hertz. because the sub i have (little 10 inch from wally world) cant reporduce 15 hz very well..
am i on the right path to makin more vibrations or am i barking up the wrong tree?
oh this is for a physics project. i need this sub to make alot of vibrations to shake something loose
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
If you google and download audacity you can create sine waves. Realm Of Excursion has a download section where you might find one.
Not sure if that answers your questions. Are you trying to build an enclosure to help it do this or free air or what?
tejcurrent
XS Power
T3
would be easier to use a larger diameter driver like a 15", 18", or 21" sub.
You would need to build a large sealed enclosure and use an amplifier without a subsonic filter.
You can use a tone generator or even a test CD with recorded test tones in that range.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
well here is the deal
the sub, amp and box are kinda set in stone. so none of that can be changed. its a 1.5 or so cube enclosure. not sure on tuning tho. (bought it at a yard sale)
i have audacity and i have been messin wit different frequencies
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I was going to mention, what you can do is get 2 subs, and 2 boxes, and tuned them about 7.5 hz or 15 hz ( I forget which ) separate from each other to make 15hz
without strain on a sub actually producing 15hz
should be like 1 box at 30hz, and the other 45hz, playing same tone
  • Who's Online   0 Members, 0 Anonymous, 1396 Guests (See full list)
