Ok, so I'll just get down to the specs, this is my first computer that I've built...
Mobo: EVGA 790i Ultra SLI FTW Edition
CPU: Intel Core 2 Quad Q6700 ***OVERCLOCKED***3.33GHz == 1333FSB, x9 Multiplier***
Cooler: Zerotherm BT90 Copper
Video Card: EDIT: XFX GTX 260 XXX Edition ***OVERCLOCKED***SPECS BELOW***
RAM: Corsair 2x1024Mb DDR3 1333MHz
Optical: Lite-On BluRay Player
HDD: Seagate 7200.11 1.5TB 7200RPM SATA
Power Supply: LSP 750W Pro
Case: Ultra Gladiator
Still need to get (2) 120mm Case fans, but running fine now
CPU was overclocked with BIOS
GPU overclocked with EVGA Precision Tool
GPU Stock:
567MHz Core Clock
1242MHz Shader Clock
999MHz Memory Clock
GPU overclock specs:
625MHz Core Clock
1347MHz Shader Clock
1040MHz Memory Clock
Stock everything 3DMark Vantage Score (Hard, cant do Extreme because of monitor limitations): H5610
Stock Processor, Overclocked GPU: H5967
OC Processor, Stock GPU: H5932
OC Processor, OC GPU: H6128
Anyone else run this test? What scores did you get?
...pics coming soon
Edited by +ZER0Hz+
2009 VW Rabbit 2-Door:
Pioneer AVH-X1600DVD
Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm)
NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box
Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets
Owner/Founder of RT Photography
Canon Traitor who moved to Fujifilm
You really should of got a 45nm processor. The only reason the 780i and 790i were brought into the market is to have support for intel's 45nm parts.
Anyways nice build, but ddr3 is a waste on socket 775. The memory controller is the limiting factor on socket 775, and that is why DDR3 is properly used on the nehalem architecture.
Edited by Moti
Well i saved a few bucks by getting a barebones which had the case, mobo, graphics card (which I got the XFX version instead of the EVGA version), processor, ram, hard drive (which is another story, I ended up with 1.5 tb instead of the 1 thats in the kit) and power supply. I just had to get some simple shit.
I finally got my fans, graphics card tweaked a lil higher, getting around to getting the cpu up there.
Heres a link to the barebones: http://www.tigerdirect.com/applications/Se...8&CatId=333
I just checked the diff in price for the graphics card: def. got a $269 graphics card for the price of a $219 card.
I HAZ PICKTUREZZZ!
Oh, and I got the 2nd GTX 260... new bench score: H11372
EDIT: OK, pictures up and running
Edited by +ZER0Hz+
...running windows index level. Prolly wont work...again
edit: ...what did I tell ya? What are some popular tests that I could run to show how well it runs?
Edited by +ZER0Hz+
3dmark Vantage: P20,070
3dmark06: 17,xxx.
Super pi 1M: 15.266
