Eskii Posted November 20, 2008 Report Posted November 20, 2008 Been working on designing an enclosure for 3 10" BL's running off a T4k. Came up with an enclosure of net 1.5 cubes. Tunned to 32, it has 2 ports of length ~11.5" and total area of 18" square Any suggestions on errors or areas for improvements?? Cheers Previous: 1988 Nissan Patrol Rockford T800.4 Rockford T1 15 (sealed) Rockford 6.5 Components Current: 1997 Jeep Wrangler Build goals... 1x RF P300.2 4x Hertz HCX165's Built Completes Alpine 9886 Headunit RF P300.2 RF P500-1bd 2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz 4x Hertz HCX130's Current comment... Satisfied for the moment, focusing on performance upgrades
AI James Posted November 20, 2008 Report Posted November 20, 2008 you dont think a half cube each is a little small for them?
Eskii Posted November 20, 2008 Author Report Posted November 20, 2008 Well it's 1.5 with an ass load of bracing etc, so i can work with max 2.4 cubes. Just want it tight so i can feed ~1500W to each. I believe that's a fair amount of power for at BL 10. What's yours suggestion for net vol?? Previous: 1988 Nissan Patrol Rockford T800.4 Rockford T1 15 (sealed) Rockford 6.5 Components Current: 1997 Jeep Wrangler Build goals... 1x RF P300.2 4x Hertz HCX165's Built Completes Alpine 9886 Headunit RF P300.2 RF P500-1bd 2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz 4x Hertz HCX130's Current comment... Satisfied for the moment, focusing on performance upgrades
AI James Posted November 20, 2008 Report Posted November 20, 2008 well being that they are 1500rms subs, the recommended box sizing from Fi would be where i would start at, your half a cube net is going to make the subs bery inefficient. they should nbe able to take the 1500 rms each without you miniaturing the box it you absolutely cannot get anymore room ai would advise against using 3 10s of BLs
Eskii Posted November 20, 2008 Author Report Posted November 20, 2008 fair call... back to the drawing board! perhaps 0.8 cube could work with the T4k amp, or step up to more power?? Could i run 2 amps strapped to 3 subs (3 VC per amp), or is that not advisable.... Previous: 1988 Nissan Patrol Rockford T800.4 Rockford T1 15 (sealed) Rockford 6.5 Components Current: 1997 Jeep Wrangler Build goals... 1x RF P300.2 4x Hertz HCX165's Built Completes Alpine 9886 Headunit RF P300.2 RF P500-1bd 2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz 4x Hertz HCX130's Current comment... Satisfied for the moment, focusing on performance upgrades
AI James Posted November 20, 2008 Report Posted November 20, 2008 i wouldnt do it, and .8 each is still to small imo your looking at 1 cube each at the very least, as your not going to get a true 1ohm load out of 3 subs no matter how you wire it. and the rf while being a good amp will be just barely if at all giveing the 3 rms power
osixfrontier Posted November 22, 2008 Report Posted November 22, 2008 2 bls willl eat that amp with 2.4 after all displacement.... i had my 1 bl10 taking a z1 at .7 with 1.4 cubes for several months before i sold it....... 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
