power acoustik a3000db vs bx2005d
thegr8cody
The amp was installed flawlessly, minus a lil long on the battery cable side, all wound up in a bundle by the amp. Ive installed a few thousand amps in my days, well, realistically in 12 years, high hundreds, and I never seen an amp do that. Iam buying a new one, should get here 3 business days from friday, and this one is goin back. Definitly a defective amp. But that pop was loud! Guess thats what a150-160amp 14volt explosion sounds like... lol  Iam not that mad any more, but frusterated I have a 300lb speaker box, second battery, pre amp, and a shit load of 0/1 and 2 gauge floating around in my truck, and no amp till tuesday (or monday)
I really wired the subs up perfectly in the box. I used a power cable from a 240v dryer, so I had 10/8 awg speaker wire, with factory ring terminals, and I also used alum power dist blocks from Home Depot for hi volt wiring, and 5/16" brass bolts as terminals---- just that damn amp
GRRRRRR
i fugured it was a lemon. so is the company you bought it from replacing it for free.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
They better take it back, I havent been able to contact them yet. I found out to late they close the store 1pm east coast time, so I will be able to talk to them on monday. But I already ordered a new one, will be here tuesday... I rewired everything again, and tested with my neighbors amp, all worked fine, with and with out the BASS10, I also turned the pre out voltage down to min on the Bass10 think it was 4volts now
yeah that bass-10 thing comes on the highest voltage wich is like 10 volts or somethin, i forgot. it should work better on a lower setting
DD M4
that might be it, possibly. IT DID come at highest voltage setting which is stupid, I did have gain down. And also, I was testing at about 8ohms mono, so even if it was set at 10vrms, I doubt the FETs would have exploded that way, especially with  gain down all the way on the bass10, slowly turning gain up.... oh well... tomorrows the day, and I have a new 7.0mp digi cam, ready for pics
:w00t:all right. lets get some pics up in her.
DD M4
its in hurrrrr  u nub  :ninja:  :tongue:
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
DD M4
  • Who's Online   0 Members, 0 Anonymous, 1176 Guests (See full list)
