just doin some lookin on the forums i found that these are very good SQ drivers.
so i got an idea. instead of tryin to fit 2 15's wit a 3-4k rms power why not stuff this beast in a t-line in my trunk off 1k rms. it would be cheaper cuz i wont need to upgrade my electrical to power it and it should sound damn good.
i just kinda want some opinions on the idea. wut kinda output could i expect from this thing?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i have never heard an sq driver b4... so most likely id be dissapointed? alright then
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Very punchy sub and can get loud in the right setup - someone here pulled over 140dB with a idmax 12 in a ported box with about 1000w on it.
One thing to note is that they love 1000w but if you go a tiny bit over that they'll burn up quick as.
A setup I helped my friend with has a 10" idmax in a 0.65 cube sealed box with close to 1000w on it and it sounds very very decent. Gets loud-ish too, loudest sealed setup I have ever heard apart from my SPL box with the port blocked :lol:
10.x volts fo' life!
I got a 142 or 143 out of a idmax 12 powered on a treo 1500. I would plug the port for daily use and when purped at the same settings 10db less in spl.
My box was around 3 cubes.
I got lazy and just tossed an 18in apx to get it louder. idmax is a cool sounding sub!
08 World Finals Judge - Laughlin
07 World Finals Judge - San Mateo
Team Treo
www.myspace.com/boominaudio
i did two of these subs in a sealed setup in a pt cruiser sounded great with about 2000 watts on them never had any problems them very punchy bass i noticed you said you were going to do a tline in the trunk ??? if you want it loud you might want to do a ported box withe port coming through the rear decklid or if possible into the rear armrest if applicable what car do you have
must be nice huh
  • Who's Online   0 Members, 0 Anonymous, 4864 Guests (See full list)
