hawkins6423 Posted November 29, 2008 Report Posted November 29, 2008 Has anyone ever heard of inverting the btl? I just got 2 12" and I want to invert them in a wall setup in my dodge ram. I believe it would work if you just flip the rubber gasket right? Any ideas?
Guest Fi-Beat-Down Posted November 29, 2008 Report Posted November 29, 2008 http://www.youtube.com/watch?v=zwQW-zHbZbQ FI 18 Inverted video why would you want to do that anyways?
hawkins6423 Posted November 29, 2008 Author Report Posted November 29, 2008 Well the magnet looks pretty sweet on the 12" considering it's just about as big as the cone, and I'm doing something similar to what this guys doing: http://www.stevemeadedesigns.com/board/ind...;hl=steel+frame Do you think it alters quality at all? vs. being inside the box.
Decaf Posted November 29, 2008 Report Posted November 29, 2008 it will increase box volume and lower tuning... so as long as u account for that ur fine u might also hear mechanical noises that would have been attenuated inside the box otherwise... ive had an 12" re se inverted for ~4months and never noticed that... nor had any problems... it should cool the sub better also since its not in a hot box edit*my bad
IH8PunkRok Posted November 29, 2008 Report Posted November 29, 2008 it will increase box volume and raise tuning... so as long as u account for that ur fineu might also hear mechanical noises that would have been attenuated inside the box otherwise... ive had an 12" re se inverted for ~4months and never noticed that... nor had any problems... it should cool the sub better also since its not in a hot box i thought it lowered tuning? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Decaf Posted November 29, 2008 Report Posted November 29, 2008 my bad... corrected... at most ur looking at ~.5-.75hz lower tuning than if inside
hawkins6423 Posted November 29, 2008 Author Report Posted November 29, 2008 is there an advantage over a straight port than a L port design?
finkster Posted November 29, 2008 Report Posted November 29, 2008 is there an advantage over a straight port than a L port design? air flow, maybe. make sure you round your corners DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Decaf Posted November 29, 2008 Report Posted November 29, 2008 is there an advantage over a straight port than a L port design? if both slot ports... the L-port just needed to be longer then the depth of the box so there needs to be a 90 degree turn to allow for lower tuning
