3 Kicker L7 15's
1000rms Dual 2 VC
Wiring would come down to 1.34 ohms.
Just wondering if this would be smart. Dont want to fry a amp. What ohm stability would i need?
Clarion ProAudio VRX755VD
Infinity Perfects 6.1-front
Infinity Perfects 5.1 -rear
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
Pair of Memphis tweets
New Build In The Works
A Sundown 3000 would power them pretty good.
Edit: Actually, two Sundown 1500's would be better.
Or any amp that is one ohm stable.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
You need atleast a 1ohm stable amp and if you strap 2 saz-1500ds together it has a 2 ohm load wich meens there gonna start getting hot pretty quick unless you turn them down. Im guessing this is a daily driver. I would go with the saz-3000d but your onlygonna be getting probley a bit over 2500. This is good though so you dont fry the kapton voice coils in the l7s. Over powering them is not smart. 0.02 :-)
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
Not true. By the time you get box rise you should be around 2 ohms for the pair of amps. Even running any Sundown amp (SAZ) at .5 ohms they don't get hot.
I do box designs.
Sundowns wil get hot at 0.5ohms on a daily driving car. There is a reason jacob doesnt warant them at 0.5ohms any more. They only recommend 0.5ohms for burps. As far as a 1.3ohm load on 2 saz-1500ds strapped with a 2ohm stability Im not sure how hot it will get. Im only stating that Jake nore db-r will warrant running them lower than the recommend ohms stability.
If your Sundown amp gets hot...your doing something wrong!
I do box designs.
Dont take this the wrong way Im not trying to argue just learn something new in case Im wrong. How much of a load have you had on your sundown for how long before it gets hot? :unknw:
I've had 1.22 ohm final load and my saz-3000 it has never even been slightly warm .
250 amp mechman alt
Sundown 100.4D
Sundown 1500v2 now goin to the cruze
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
Trying something new
2011 Chevy Cruze
X8
1500v2
Where talking about strapping 2 1500ds at 1.34 ohms while a 2 ohm load is the lowest rated resistance. And another thing the rlp-18s that are in your avatar. How do you like them. I know there an sq sub but how are they as far as spl goes? And what app are you using them in?
Edited by Zade08
  • Who's Online   0 Members, 0 Anonymous, 2084 Guests (See full list)
