Custom Subwoofer Now For Sale..pg 4
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Finished
A few things I'am upset about, my crappy solder iron took a crap out on my finally in the middle of soldering the VC leads to the spider leads, then I bought a new solder iron, the trigger style, actually works alright for $12.99, but then I was using ring terminals for the terminals, someone tossed the bag of m4-40 nuts for the terminals, so I ended up soldering ring terminals when they needed to be tightened down
I had a little bit of lead slap it sounded like, but I think it might have been the amp clipping- Joy
I used the DVC 1ohm coil, not the 2ohm coil I was thinking of- haha oh well, its assembled right, looks tuff, and tested fine while sweeping it
I need new domes!!! I want inverted alum domes, or CF domes, or even poly domes- hint hint- if anyone has any???
Thanks ....
Whats gay is that I only have a 4ohm mono amp, 2 channel 2ohm amp- class A/B- nothing special to test this woofer with. I have a temporary sub in my truck now that is a 6ohm parr sub, getting about 350-400rms, built on the same structure as this sub here. This one I just did a little modifying
Thanks ....
damn man, that's the bad thing :sad: all subs should link through and be able to chose ohm loads in an instant... haha
but let's see some vids when it's up and going
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
Sub looks great! Got any vids of it playing? :)
I got 2 DD 6.5 inch carbon fiber dust caps, but they are closer to 7 inch. One is a tighter weave and the other is a bit larger weave.
Posted Image
I wouldn't mind some large cf domes
Posted Image
Oh I thought you said you had some CF domes from the 6.5" DD subs, but those are about 7" CF domes from larger subs.. hmmm
I have like 25- inverted alum domes, but the only problem is, they are TOO inverted, and usually interfere with the soldered leads under the domes, thats why on this sub I used so much RTV so they don't effect the solder, break, or slap against the aluminum dome, the foam padding was meant as a kind of "Pinging" damper- common issue with alum domes
