Well, When I was driving my 95 Lt1 it just shut off out of nowhere and the Check Engine light came on.
The car wasn't even running hot or anything like that.
I tried starting it but it would just turn over but not start.
I waited a couple of hours to see what happens and again it would turn over but not start.
Also I can't hear it purging when I put it on the ON position.
could it be something to do with my fuel delivery? it has a new fuel filter btw.
I hooked up an obd1 scanner but the check engine light stays on it doesnt blink to give me the codes.
The obd1 scanners manual says that if this happens to do a ''Diagnostic Circuit Check''
How do I do this? I dont have the vehicle's manual
What can I do?
Edited by 95pimpalass
Might be a bad opti spark, dead fuel pump, starter or something else. I know LT1 is infamous for spark issues. Those optis go bad and nothign will work lol
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
Might be the alternator check it.
2003 Mercury Marauder Black (R.I.P)
Tinted Windows
Purple HID's 10000K
Fog Light HID's 10000K
Swi Jack Steering Wheel Controls
Apple I-Pod Classic 80GB
Alpine KCE-422i Full Speed I-Pod Cable
Alpine IVA-W203/P1 Navigation/Bluetooth
Alpine PKG-M780 7' Headrest Screens
Alpine PXA-H701 Sound Processor
Alpine MRP-F300 4 Channel Amp
Rockford Fosgate 1501bd Power Amp
2 Kicker L7 15' Solo Barics
Alpine Type R SPR-17S Component's
Alpine Type R SPR-57C Coaxial's
Monster Performance RCA's
0/2 Gauge Wires
BIG III W/Fuse
200 Amps Custom Built Alternator
Yellow Cap Optima Battery Front
Xstatic Batcap 800 Back
Custom Mounted Bass Knob
LED's 2x License & Trunk Light
BoYo VTK-350 Color Backup Camera
Dynamat Xtreme Front Doors & Rear Deck
Clifford Matrix 50.7X Alarm System/Remote Start
its either not getting spark or not getting fuel. My guess without seeing the car would be fuel pump.
and btw its not the starter as stated above if the car cranks. :rolleyes:
Edited by dadillac27
1996 Chevy blazer
Pioneer deck dehp6800mp
clarion eq
Hifonics BXI1606d (Subs)
1 18" RE MT
Box specs: 6.7cuft @35hz 14.2sqin of port per cuft (Noobtastic design)
Crunch GP1400.4 (Mids & Highs)
Boston Acoustic mids and highs
Stock alt
Stinger SP800
Bunch of 0 and 4 gauge wire
He did say it wouldnt turn over and start. If the starter is about done then it wont turn the motor completely over. Means it could be on its last leg. I had to read it a few times over to make sure i got all the info
1997 2 Door Blazer
SBC/TH350
Thanks alot for the help..
It was actually the optispark unit that had caused this problem.
I had changed the optispark about a year ago for a brand new one, but what caused my problem was my bad waterpump which was leaking fluid into it causing it to get all corroded, ( waterpump basically sits on top of the optispark)
So got a new waterpump, thermostat, and optispark and now its all gOOd! :D
I was late on this but my whip did the same thing. I had to put an opti spark, plugs, wires and water pump and the beast is back to terrorizing the wicked Chi.
1996 Impala, just a weekend toy Molesting the wicked streets of chitown (next in line for sounds)
2006 Corolla...current audio head ache and money pit
Alpine cda 9881 head unit
pioneer 6x9's
Hiphonics 6.5 components
power acustik tweeters
Not installed but in the to install list:
Hifonics Brutus BXI 2080D 2600 watts rms
2 12" Kicker L7's Dual 4 ohm subs wired at 2 ohms each = 1 ohm load
0 gauge wire, MLA module
  • 7 months later...
