Alright, now that the amp and subs are on the way, it's time for you guys to help with the Electrical. I figured that since everybody helped me out with picking the right amp(s) (check the amp choices post under the amplifier forum), we may as well keep the ball rolling with this. You guys have kept me thinking about different setups this whole time, and it seems like it's boiling down to the best sh** so far. Here is the breakdown at the moment: For sure I have 2 Kicker S15L7 Dual 4 ohms, and one RF T20001BD (birth sheet says something crazy like 2811 RMS at 1 ohm). Then comes 2 sets of polk components for the front, and 1 set kenwood components for the back doors (1995 suburban) These will have a 100x4 RMS front and a kenwood PS150 for the back...........
So, is it going to be a Iraggi H.O alternator, 2nd red top, alumapro 5 farad C.A.P, wind or hampster powered generator, or what? I've been set on a new alternator and cap w 0 gauge to the sub amp (right now the cheesy ebay 200a alt and 1f cap suck bad, only running 1200rms), but as always, I'm totally open to any suggestions. Like I said - the only things in stone right now are the subs and 3 amps. If things keep going this way, this'll be a stevemeadedesigns.com forum built Suburban of face pounding craziness, at least I hope so. Late.............Pat
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
Crap, almost forgot the money thing. I'm thinking on spending 3-400 on wiring and battery or cap, more if I need the new alternator, but hopefully If I need the alternator, the xtra battery might not be needed, or the cap won't be needed, whatever.....late, Pat
Forget the Cap, go with an H.O. Alt and a 2nd batt.
1 or 2 runs of + 1/0 wiring front to amps
1/0 the big 3 and you should be good
i think david it explained it all .......
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Its gonna be some work running the wire, but the benifits are wll worth it.
300A if you can afford it, it will have lots of power available incase you upgrade later down the road.
Well, now I have to post my props for Dominick Iraggi. I caught him closing up, and he still took the time to BS a little, and figure out what I needed. He said to go with the 260 amputator with a second redtop because it'll be better at low rpms/daily driver style. It gets 8 miles a gallon and dosn't go over 3500 RPM's anyways, so good call on his part. It's nice to talk to somebody who dosn't try to sell off the most expensive thing he has all the time - So, good call david, and thanks to everybody. Unless there are problems, the next new post from me should be showing off the rebuild......... :P  :^  <-- that's what I'll be doing when it's done --- late, Pat
still waitin for your alt?  Call him and ask whatsup.....
Follow my Tweet (Twitter)
  • Who's Online   0 Members, 0 Anonymous, 1030 Guests (See full list)
