mr.p Posted December 21, 2008 Report Posted December 21, 2008 just ordered my amps and im wondering around how much juice it will take to run 8000w daily? I am planning on a 200amp alternator, and 4 deka intimidator group 31's. If this doesnt workout i will then work on getting another 200 amp alternator and braket fabricated by a machine shop or something of that sort. How bad will the voltage drop be with this setup? with three runs of 0 for + and 3 for - to the rear. Quote DCAUDIO BALLS DEEP
CHINO11550 Posted December 21, 2008 Report Posted December 21, 2008 I have a 4000 watt amp with a 200 amp alt & i dont think the alt is enough Quote H/U Pioneer deh80prs w/ HRT iStreamer Ipod DACFront stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweetsamp running 4mids, Mosconi Audio 300.2amp running 8tit & alum tweets, Mosconi Audio 200.28 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'zbox is a 4th order band passbatts. 1 XS Power D3400 under hood,6 D3100 in back2 XP 370 amp DC Power alts.MLA module 15+voltsAll in a 97 2door Tahoe LT2010 West Coast Reg. 140-149.9 Bass Race Champ Team Bass Hz
Bigg Boy Posted December 21, 2008 Report Posted December 21, 2008 I think you'll be ok depending on the amps I had about 10kw in my tahoe with 2 runs of 1/0, 200a alt, 4 hc2400, 2 everstart.... never dropped below 14v Quote Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
Neo_frog Posted December 21, 2008 Report Posted December 21, 2008 I think you'll be ok depending on the ampsI had about 10kw in my tahoe with 2 runs of 1/0, 200a alt, 4 hc2400, 2 everstart.... never dropped below 14v What kind of amps were you running though Bigg Boy? I'm running 4000W on 300A alt, 4 runs 1/0, MLA module and I see almost 2V drop at full tilt. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Bigg Boy Posted December 21, 2008 Report Posted December 21, 2008 xt-4000 plus 4 highs amps Quote Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
mr.p Posted December 21, 2008 Author Report Posted December 21, 2008 i didnt want to let the cat out of the bag until i got them delivered but they are mmats 4000.1 and they are modded with no protect so they can run below 1 ohm, i shouldnt drop them that low though. 76% efficient i believe or somewhere there at full tilt. Quote DCAUDIO BALLS DEEP
Bigg Boy Posted December 21, 2008 Report Posted December 21, 2008 you planning on running this daily? or burps or what? Quote Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
ChevyBoy Posted December 21, 2008 Report Posted December 21, 2008 What kind of amps were you running though Bigg Boy?I'm running 4000W on 300A alt, 4 runs 1/0, MLA module and I see almost 2V drop at full tilt. then you have a serious problem i didnt want to let the cat out of the bag until i got them delivered but they are mmats 4000.1 and they are modded with no protect so they can run below 1 ohm, i shouldnt drop them that low though. 76% efficient i believe or somewhere there at full tilt. you mean this cat? http://www.stevemeadedesigns.com/board/ind...st&p=495342 Quote
mr.p Posted December 21, 2008 Author Report Posted December 21, 2008 yep 2 of them. might setup for burps not sure tho im planning on them 1 ohm each daily. Quote DCAUDIO BALLS DEEP
Big Rrd Posted December 21, 2008 Report Posted December 21, 2008 i run 2 power bass 4000D 1-200 amp alt 10-stinger 1700 daily and i have to watch my voltage at full tilt but i can make a full day at a show Quote
